Turn Signal Question
Old Apr 17, 2007 | 07:18 PM
JChase's Avatar
JChase
Default Turn Signal Question
I have a 65 mustang and my turn signal wont cancel (stop clicking) whenI complete my turn. I have to reset it to center (between left turn and right turn position)by hand. Does this sound like a turn signal cam problem? Need help. Thanks
Old Apr 17, 2007 | 07:33 PM
66GTKFB's Avatar
66GTKFB
Default RE: Turn Signal Question
It most likely the trip arm in the switch - as in you need a new switch. The switch assembly also contains the horn contacts and the wiring harness. Hint, the second one you do is always easier.
Jim
Old Apr 17, 2007 | 10:46 PM
restomod66's Avatar
restomod66
I have the same problem with my 66 coupe. I just move it back manually for now seeing its an automatic transmission and requires no shifting.
Old Apr 18, 2007 | 01:28 AM
connor90's Avatar
connor90
ya, happens in mine. can be annoying but not one of my more pressing issues so i just leave it as is.
Old Apr 18, 2007 | 09:28 AM
sxs191's Avatar
sxs191
+1 with 66GTKFB. I had the same problem, it's the trip arm in the switch. Here's the peice that's broke.. http://www.mustangsunlimited.com/ite...p?T1=127208+01
Old Apr 18, 2007 | 09:54 AM
JChase's Avatar
JChase
Hey thanks alot. Thats actually the part I ordered hoping to fix it..........
Old Apr 18, 2007 | 10:34 AM
UBY289's Avatar
UBY289
GTKFB, do you need to pull the steering wheel or just the horn assembly?
Old Apr 18, 2007 | 10:37 AM
sxs191's Avatar
sxs191
You have to pull the steering wheel to get to the horn assembly. At least with my steering wheel you do.
Old Apr 18, 2007 | 10:39 AM
sxs191's Avatar
sxs191
The switch is in the steering colomn so I imagine you have to pull all steering wheels. (ofcourse I could be wrong)
Old Apr 18, 2007 | 11:02 AM
UBY289's Avatar
UBY289
Maybe thats way everybody waits to do last if the wheel has to come off.
