Engine Mounts
Old Apr 18, 2007 | 12:46 AM
Loza_69Mach1's Avatar
Loza_69Mach1
Default Engine Mounts
I need to get more motor mounts and i dont know if i sould just go with the regular ruber kind which are 10 dollars or should i buy the high performance ones that are about 140. The price difference is alot but im not sure.... my motor isnt so high performance but its mild.... im not sure... thanks for the help..... any storys or anything.... thanks
Old Apr 18, 2007 | 12:50 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Engine Mounts
If you have only done some minor performance upgrades, then the stock mounts will work just fine. Those 140 buck guys are for serious horsepower engines.
Old Apr 18, 2007 | 01:40 AM
latamud's Avatar
latamud
A trick I learned from my friend John Dinkel when using stock engine mounts. I know its probably been done before John thought of it, but I dubbed it the Opentracker engine mount mod. Drill a hole through the driver's mount top to bottom, and dril a corresponding hole in the frame mount. Run a grade 8 bolt with big washers on bolt ends and a nylon lock nut on the other side. Tightn it down only to where the rubber just slightly gets tight. The weakest link in the mount is the driver's side rubber, over time and torquing it will separate allowning the engine to jump over. This through bolt works as a torque strap. I'm using stock engine mounts in the mustang with this mod. I'm hoping for 600+hp with a supercharged 408 Clevor. This works on early 65 mounts as well as late 65 up mounts.
Old Apr 18, 2007 | 01:43 AM
dcohen's Avatar
dcohen
not exactly sure what your talking about with the bolt through the engine mount. Got any pics?
Old Apr 18, 2007 | 01:51 AM
green_blurr's Avatar
green_blurr
My engine mounts made my engine sit kinda lopsided is this normal ?
Nick Oliver
Oct 17, 2018 04:22 AM
ChampInSD
Oct 2, 2015 04:55 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 1, 2015 08:16 PM
