single to dual exhaust conversion
#21
RE: single to dual exhaust conversion
A picture (drawing) is worth a thousand words. If these turn out too small.I'll resize them. The bracket was drawn before I knew which way it went, so it's upside down in the fabrication drawing. The 'A' and 'B' dimensions are from two different cars with factory dual exhaust systems and I just wandered out to my garage and took a look at a third with the same setup. That one has a 90 deg bend in the bracket. It fits without a problem so the bent angle is 'flexible'. What you should avoid is re-inventing the wheel every day.
Jim
Jim
#24
Just FYI, her are two pics of the brake line. One from the gas tank side and one from the floor pan side. Kinda hard to take pics with that big muffler hanging in the way, so I did the best I could.
[IMG]local://upfiles/16727/EA690569DCCF4534A75E538A92C6255B.jpg[/IMG]
[IMG]local://upfiles/16727/5A7FC41FB9F3489CADA4B8FDEC2566B6.jpg[/IMG]
#27
ya well my exhuast wad not done right i have had that brake hose burst 3 times cause the exhaust pipe melted the hose so i zip tied the line out of the way until i can get the exhaust done right
