How hot is hot?
Old Apr 22, 2007 | 11:45 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Default How hot is hot?
I have a factory temperature gauge that is, at the moment, non-functional.
I am going to remedy this in the near future but a thought came to mind.
Currently, I am running a full-sweep Autometer temperature gauge. Normally, I run about 180. It may creep a bit above 200 sitting in traffic.
Where would this temperature read on the factory gauge? When I peg the needle on a factory gauge, what temp am I at?
Old Apr 22, 2007 | 11:46 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: How hot is hot?
idk but 200 is nowhere near overheating
Old Apr 22, 2007 | 11:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
212 is boiling.
Old Apr 22, 2007 | 11:48 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes but not in a closed pressurized system thats running antifreeze instead of plain water
Old Apr 22, 2007 | 11:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Ttue dat Steve.
Old Apr 22, 2007 | 11:55 PM
Wayne67vert's Avatar
Wayne67vert
The 40 year old gauge will not be accurate with a new guage. Corrosion, rust and electrical resistance will make them read incorrectly. Most likely 2 different origonal guages would read differently
Old Apr 23, 2007 | 12:07 AM
fastbackford351
Foghorn Leghorn
This gauge package has been restored by the Clock Doc and so far his work is dead nuts on.
What is the temperature range that a factory Mustang temperature gauge reads?
Anybody?
Old Apr 23, 2007 | 12:59 AM
66GTKFB's Avatar
66GTKFB
It was a generic warm and too hot indicator. If you were driving insnow country, it read cooler than the same car would in the desert, by design (remember the thermostat). There were no specs published for the consumer and any two would read 'warm' or 'hot' depending on the situation - your choice.
Jim
Old Apr 23, 2007 | 01:14 AM
Soaring's Avatar
Soaring
I ♥ Acer
If you can get a gauge to read your water temp correctly, and you trust that gauge, then these engines run best between 180 and 200 degrees F.
Old Apr 23, 2007 | 01:29 AM
fastbackford351
Foghorn Leghorn
I wikipedia'd Thermistor and I found it to be a fasinating read.At least the first several paragraphs and then my head began to swim from info-overload.
What you said about it being a "generic" temperature indicator seems to fall in line with the definition given there.
Good poop.
