Hard starting when warm
Old Apr 24, 2007 | 01:23 AM
  #21
66GTKFB's Avatar
66GTKFB
Default RE: Hard starting when warm
[quote]ORIGINAL: andykbob
Hey, I seem to have a problem starting my 351 when its warm. It turns over fine when it's cold, but when it's hot, it barely turns over and sometime it just won't turn it over. I had the battery checked and was told it was fine. The batterey, voltage regulator and alternator are new. I was told that my timing could be too advanced so I backed it off. It seemed to work for a day but then it did it again.
Any thoughts?
[/quote
Start all over guys. andykbob said the engine will not turn over when hot. Not fuel, not coil - starter.
Jim]
Old Apr 24, 2007 | 01:37 AM
  #22
mustanglover66's Avatar
mustanglover66
go to autozone with the engine hot and have them test the starter on the car that will answer the question of the hot starter, which I would bet is the problem.
Old Apr 24, 2007 | 01:53 AM
  #23
BigIron22's Avatar
BigIron22
i had the same problem with my 351w it turned out to be the ground wire from the block was too small. i added another ground wire (4ga)from the ear of the starter straight to the neg terminal on the battery. no more problem.
Old Apr 24, 2007 | 03:10 AM
  #24
1bandc69's Avatar
1bandc69
What carb and intake are you using? If it is an edelbrock/carter carb on a no air gap intake, it is usually vapor lock. This can be fixed with a heat insulator gasket. A one inch is usually not necessary, and will effect where you engine liks to run(usually at higher rpm since the velocity is higher entering the runners).
Old Apr 24, 2007 | 03:23 AM
  #25
andrewmp6's Avatar
andrewmp6
heres a question thats never been asked whats the compression of the engine high compression and hot will do that with a normal starter
Old Apr 24, 2007 | 03:55 AM
  #26
badazz68stang's Avatar
badazz68stang
ok, im having trouble figuring out how vapor lock will cause the engine to not turn over at all.
Old Apr 24, 2007 | 01:00 PM
  #27
67SuperSnake's Avatar
67SuperSnake
ORIGINAL: andrewmp6
Thought about that last night, also! True...
Old Apr 24, 2007 | 10:45 PM
  #28
andykbob's Avatar
andykbob
OK Lets see.
The Alternator and Battery are nre
No there is no Spacer under the carb
The Carb is a Holly 750
No Idea about the compression thing
The New coil is the actuall measuring 2.5 volts now. I think I should test is with a different meter.
I think thats it
Old Apr 24, 2007 | 10:51 PM
  #29
dr1965's Avatar
dr1965
how can you prove weather it is vapor lock?
Old Apr 24, 2007 | 10:59 PM
  #30
andykbob's Avatar
andykbob
Anyone know where I can get a good high heat starter?
