cleavor
Old Apr 23, 2007 | 11:13 PM
shhswrestler215's Avatar
shhswrestler215
Default cleavor
i was reading i belive car craft and they said that they take the cleavand heads and put it on the windsor block now from what i read the 4v heads from the cleavland is it a overhead cam or dose it use the stock windsor cam location if so how do they get the extra 2 lifters im just thinking about it from pictures maybe im just wrong if someone could clear it up for me thankyou aslo if you know how to do it at home im looking to try to build it at home
Old Apr 23, 2007 | 11:24 PM
eholzer07's Avatar
eholzer07
Default RE: cleavor
I believe that there has already been a very long thread on the cleavor engine on here. Go to search and check it out to see if it is still there.
Old Apr 24, 2007 | 12:27 AM
easttennmotors's Avatar
easttennmotors
Default RE: cleavor
4v refers to 4 venturi as in a 4 barrell carb, but yeah im not trying to be mean but you probly should just stick to the basics till you learn some more about the cars and engines...
Old Apr 24, 2007 | 04:00 AM
andrewmp6's Avatar
andrewmp6
Default RE: cleavor
heres how to do it http://www.themustangshop.com/clevor.cfm
Old Apr 24, 2007 | 04:11 AM
superdavid's Avatar
superdavid
Default RE: cleavor
Which would be better, that or just slapping some good aluminum heads on my 408W?
Old Apr 24, 2007 | 04:16 AM
atomsk680's Avatar
atomsk680
Default RE: cleavor
ORIGINAL: easttennmotors
no he is talking about the heads, theres a 4V design and a 2V design
to answer our question there isnt 2 extra lifters, and its not an overhead cam, its a single cam with pushrods
Old Apr 24, 2007 | 06:57 AM
andrewmp6's Avatar
andrewmp6
Default RE: cleavor
superdavid id go with aftermarket heads they weight less and flow better and no drilling order a special intake manifold or gaskets
Old Apr 24, 2007 | 04:41 PM
shhswrestler215
Default RE: cleavor
[/quote]
[/quote]
then how do they get the extra valve i had reread the article today (good use of my parents tution money there huh) and they used 3v heads
Old Apr 24, 2007 | 04:47 PM
atomsk680's Avatar
atomsk680
Default RE: cleavor
ORIGINAL: shhswrestler215
i know theres not a cam in the head case i have a 351C with 4v heads and theres no cam in there
the difference betwee 2v, 3v, and 4v isnt the number of valves, they all had 2, just the higher it went, the bigger the valves were, 4v obviously having the biggest
Old Apr 24, 2007 | 07:16 PM
Decurion's Avatar
Decurion
Default RE: cleavor
hEad SPinNinG...!Ahh! MuSt...leAve thReAd .. NOW...! AARrrRggGgGhhhH!!!!
ugh, I dont even know where to begin... [8D]
