From: NE Tx Pineywoods & Lost Pines area SE of Austin
RE: Monte Carlo bar dimensions
I am just finishing up front suspension rebuild, including shelby control drop, granada discs, steering linkage,new brake lines, fuel lines, now stripping and repainting. Do you have it now Doof?
fair do's. Some body had some fatastic billet export brace or stiffer stock replacements can remender the guys name but was on board a fair bit this month.
Looks good James! Did you buy the bar as is or have it swedged and tapped yourself? Does it use left and right hand threads so it can be adjusted without removal? Is that bracket a frame rail bracket for a clutch? I'm assuming that it is strong enough that it doesn't flex even though it is in single shear as it probably doesn't see tremendous loads.
