Gas tank
Old Apr 27, 2007 | 04:22 AM
crose66's Avatar
crose66
Default Gas tank
If i am going to replace my gas tank in my 66 stang should i just buy another original or look for a better one (after market).
Old Apr 27, 2007 | 04:48 AM
andrewmp6's Avatar
andrewmp6
Default RE: Gas tank
id go aftermarket they look just like an original with out the chance of it it leaking or being full of slug
Old Apr 27, 2007 | 03:01 PM
crose66's Avatar
crose66
sorry i didnt make myself clear...should i buy a brand new one out of a catalog that looks just like an original or should i find a better one to throw in there.and if a different one what kind?
Old Apr 27, 2007 | 05:20 PM
66GTKFB's Avatar
66GTKFB
You can't get an original, except at a very high price. The aftermarket ones are excellent and you can install a 20 gallon 69 and 70 tank. The trunk will be smaller and you should put an insulation pad over it. Most used tank, the final choice, are not worth the cost.
Jim
Old Apr 27, 2007 | 05:34 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I put the 69-70, 20 gallon tank in my 67 and while there is a bit of a loss in the depth of the trunk, the extra miles between fill-ups is nice.
No regrets
Old Apr 27, 2007 | 06:03 PM
baddog671's Avatar
baddog671
I would just use an aftermarket tank made the same way as your original. You can get kits for about 125 bucks.
Old Apr 29, 2007 | 11:53 PM
crose66's Avatar
crose66
altight thanks guys
Old Apr 30, 2007 | 12:48 AM
az1966's Avatar
az1966
see my earlier post of ........can you match this one,,,,,just swaped out the tank in my 66 coupe 200 ci ,,watch your step with the sending unit / locking ring gasket,,,,, I wound up using the new gasket plus a home made one that I made from gasket material to finally seal it up once and for all,,the locking ring will go on really tight ( a little tighter then normal) but worth the peace of mind,, if that rubber one you buy or they include shifts while your tightening up the locking ring you'll be like me watching 20 bucks or more worth of gas poreing out of the sending unit area and the fire dept showing up at the gas station,,there's no way to presure test before hand that I know of,,,, just a word of warning
Old Apr 30, 2007 | 01:18 AM
66 Restomod's Avatar
66 Restomod
The 70 tank holds 22 gallons while the 69 holds 20. Stock 66 is 16.
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
mrappe
Sep 26, 2015 10:16 AM
