c4 Transmission leak
Old 09-29-2007, 09:46 PM
lucastrex
lucastrex's Avatar
Default RE: c4 Transmission leak
Where is the vent tube located on the C4?
Do C4's ever stop seeping?
lucastrex is offline
Old 09-30-2007, 08:54 AM
73 Sportroof
73 Sportroof's Avatar
I had a leak on a C6. I would leave a small spot when I drove every day, and if it sat for a weak it would lose a quart. It was the filler tube o-ring.
73 Sportroof is offline
Old 09-30-2007, 01:12 PM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
could be a bad O ring
check the o-ring, change the gasket cork with rubber ends s what i used. sheck by the drive shaft.
ill go look at mine to see if i forgot anything.
USMCrebel is offline
Old 09-30-2007, 04:12 PM
blue66mustang
blue66mustang's Avatar
Aksi it could be the torque converter draining back into the transmission. This would typicaly happen after sitting for a few days. Replace the "O" ring on the TQ shaft and it may fix this. But then again this requires removing the transmission.
blue66mustang is offline
Old 09-18-2017, 04:04 PM
madjack
madjack's Avatar
does anybody know why my c4 leaks only after ive been at high speed for a few miles it looks like its pushing out the left rear of the pan
madjack is offline
Old 09-18-2017, 04:18 PM
Gun Jam
Moderator
Gun Jam's Avatar
are you sure its not seeping down from above? If you are sure you could try replacing the pan gasket.
Gun Jam is offline
Old 09-18-2017, 05:58 PM
madjack
madjack's Avatar
nope its pissin out the corner of the pan put a new cork/rubber gasket on it and tighten them up .
madjack is offline
Old 09-18-2017, 08:21 PM
Gun Jam
Moderator
Gun Jam's Avatar
Did the new gasket solve the problem? Or are you saying the problem occurred after the gasket was replaced?
Gun Jam is offline
Old 09-19-2017, 10:27 AM
madjack
madjack's Avatar
no it did it before i changed the pan .its a new pan and gasket. i tightened up the bolts till i thought they would snap. its better but still leaks at high speeds. is that new moroso rubber gasket with a steel core any good ?
madjack is offline
Old 09-19-2017, 10:34 AM
Gun Jam
Moderator
Gun Jam's Avatar
check the pan lip and make sure its flat, use a straight edge.
check the seating surface on the trans for cracks
steel core gasket should do well at not deforming but it shouldn't take a ton of bolt pressure to stop it form leaking. You can try using a sealent like "right stuff" on both sides of the gasket. Torque to spec using a proper toqure sequence.
Gun Jam is offline
Quick Reply: c4 Transmission leak
