Grenada disc conv. dust cap installation
Old Apr 27, 2007 | 09:26 PM
jcarden's Avatar
jcarden
Default Grenada disc conv. dust cap installation
I've been working on installing the dust cap on the rotor forever now, it seems. I'm generally a very patient person but I'm losing hope. Is there a trick to hammering them on? I've two brand new caps and I tossed the old ones or I'd try them.
Old Apr 27, 2007 | 10:51 PM
68SCode4speed's Avatar
68SCode4speed
Default RE: Grenada disc conv. dust cap installation
Crimp the inside edges a little bit but not so much that you interfere with the nut and cotter pin on the hub. If you have a very large socket that fits over the outside of the dust cap but rests on the rim of the cap then that is the best thing to have - then you just tap on the end of the socket to drive the cap in evenly. Otherwise just be patient and work around the opposite edges slowly.
Old Apr 27, 2007 | 10:58 PM
ideal_mustangs's Avatar
ideal_mustangs
I does take lots a patients. If you don't have any sockets to do as mentioned above, take a flat screwdriver and keep tapping lightly around the lip on the edge of the dust cover and eventually it will start.
Old Apr 27, 2007 | 11:19 PM
connor90's Avatar
connor90
i know exactly what you mean. i just installed mine a month or so ago and it was a pain in the ***. i ruined one of my dust caps and i could not get it in with just the hammer. i got a piece ofpipe that fit perfectly around the edge and they went in very smoothly that way. so maybe try to search around for something like that. hompe depot should have something.
Old Apr 27, 2007 | 11:56 PM
DenDen's Avatar
DenDen
I had the same problem I feel yer pain.I just used the old ones.Lesson1 dont discard anything until all the bugs are ironed out.
Old Apr 28, 2007 | 12:12 AM
jcarden's Avatar
jcarden
Thanks all. I cut off a piece of 2" pvc pipe and use it to help install the cap. It took me about 3 minutes after that!
Jason
Old Apr 28, 2007 | 12:28 AM
connor90's Avatar
connor90
hahaha...ya thats what i did. i spent like half on hour pounding on the first one before someone else suggested to use the pipe and then bam...like a min later they were both on
Old Apr 28, 2007 | 06:06 AM
andrewmp6's Avatar
andrewmp6
the big socket trick works for me if hammer only tap it on the rim in a circle never head it on the middle youll dimple the dom of it
mtgldr
Feb 3, 2024 09:00 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
