Boiling over
Old Apr 27, 2007 | 09:36 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default Boiling over
so when i drive my car its fine it runs about 1/4-1/3 of the way on my temp guage when i am driving but everytime i kill the motor it boils over but never while its running can someone help me with this
Old Apr 27, 2007 | 09:57 PM
mat11089's Avatar
mat11089
Default RE: Boiling over
Whats cooling the motor besdies coolant?Answer=Fan Question= when is a mechanical fan on? Answer=when car is on.. Its cuz u kill the car and the fan turns.Me and a friend were talking about this the other day.
Old Apr 27, 2007 | 10:00 PM
longlive289s's Avatar
longlive289s
ya u can upgrade to electrical fans and also be able to pull a couple ponies from that too. i think so models you can buy will continue to stay on a couple mins after the engine quits.....ill look around the net for a bit
Old Apr 27, 2007 | 10:06 PM
JamesW's Avatar
JamesW
Do you have a closed system? A coolant recovery tank? It is designed to accept the overflow, then when the motor cools down..the coolant gets sucked back into the radiator.
mat11089's Avatar
mat11089
ya i heard you can gain btwn 15 and 20 horses.Dont know from personal experience
Old Apr 27, 2007 | 10:15 PM
67mustang302's Avatar
67mustang302
I have a flex fan and a closed system(overflow tank) and don't lose any coolant or overheat(and it can get over 110 in the summer regularly around here). The boiling over may be the pressure relieving itself from the overflow fitting where the cap screws on. If you have no overflow, either get an overflow resevior, or you need to switch toa radiator cap designed to be used without overflow reseviors.
Old Apr 27, 2007 | 10:32 PM
Brandontyler65
I ♥ Acer
i have heard get an overflow tank should i start there cause i was gunna buy a bigger rad upgrade to a 3 row (buddy works at rad shop uber cheap) but i would rather get it workin with the stocker but it only started this after i got my cam in
Old Apr 27, 2007 | 11:47 PM
mat11089's Avatar
mat11089
if u can geta better rad cheap and can afford it do it.u wont be sorry
Old Apr 27, 2007 | 11:51 PM
valley firearms's Avatar
valley firearms
Maybe the gauge is not accurate and you are running hotter than you think. You need at least a 3 row anyway.
[align=left] [/align]
Old Apr 29, 2007 | 12:28 AM
Brandontyler65
I ♥ Acer
i know all i have is the stock 2row so i think i am gunna get one after i get a refreshed tranny in cause the way that third gear is slippin its gotta be causeing way more heat
