Boiling over
Old Apr 29, 2007 | 02:30 AM
JMD's Avatar
JMD
Default RE: Boiling over
ORIGINAL: JamesW
Do you have a closed system? A coolant recovery tank? It is designed to accept the overflow, then when the motor cools down..the coolant gets sucked back into the radiator.
+1 on the overflow tank, it was 100 in Phoenix today!
With the heat you have there, you will probably boil over some whenever you turn off your car. The electric fan(s) will probably help, but you do need an overflow setup to keep the coolant off the ground, and the air out of your radiator.
Old Apr 29, 2007 | 02:34 AM
JMD's Avatar
JMD
ORIGINAL: Brandontyler65
i know all i have is the stock 2row so i think i am gunna get one after i get a refreshed tranny in cause the way that third gear is slippin its gotta be causeing way more heat
yep a 2 row aint going to make it in the "Valley of the Sun" in the summertime. With a two row you are probably right on the edge of overheating all of the time when it is as hot as it was today and hotter.
It is going to get much hotter!![sm=badbadbad.gif]
Old Apr 29, 2007 | 04:22 AM
andrewmp6's Avatar
andrewmp6
overflow is cheap insurance on not overheating. you might try pressure testing the system if theres any air bubbles stuck it will remove them
Old Apr 29, 2007 | 08:10 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
overflow it is for starters
Old Apr 29, 2007 | 08:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, you can get an overflow tank at a junk yard for a few dollars, or just use a liter coke bottle for testing. I **** you not. The coke bottle will work just as good as any high dollar overflow tank. Then if you find that solves the problem, you can get a real overflow tank. The rubber hose is a 1/2" OD hose. Get a 13 pound cap designed to be used on an overflow system.
It sounds to me though, that you are running a lot hotter than your gauge is telling you, so you will most likely need a bigger radiator. Just save your lunch money and don't go out on a date for a few months and you will have it.
Old Apr 30, 2007 | 03:04 PM
mikethebike's Avatar
mikethebike
so when i drive my car its fine it runs about 1/4-1/3 of the way on my temp guage when i am driving but everytime i kill the motor it boils over but never while its running can someone help me with this
Are you by chance filling the radiator completely full? If you are there is no room for expansion which is what is happening during the heat soak after shut down. Without a recovery tank you need to leave about 3/4-1" of air space at the top of the radiator. My old 1980 240-d M-B had a mark on the inside of the radiator to guage the correct amount of space to leave.
Old Apr 30, 2007 | 03:25 PM
Brandontyler65
I ♥ Acer
ya actually it runs great when its about a quart low on coolant but i always refill with 50/50 and i leave it about 2in space and then plus i have bumped it up to a 17lb cap it still seems to run hot just not as hot as b4 but i think i will get a summit ovrflow tank not bad for $20 cause its a 1.5 quart but i also found out i can get not only a 3 rw rad i can use the big block rad which is larger significanly larger for $50 more
Musclecar fan_67
Aug 2, 2006 06:04 PM
GIGM08GT
Jul 18, 2006 12:09 PM
lthompson05
Jun 15, 2006 10:53 AM
mightyb28
May 31, 2006 09:43 PM
badazz68stang
Apr 23, 2006 03:10 AM
