Bouncy Ride
Old May 2, 2007 | 02:47 AM
restomod@16's Avatar
restomod@16
Default Bouncy Ride
I have a 67 coupe, and I have just replaced my whole front suspension with a new aftermarket suspension. I also replaced the rear leafs with new ones. I took her for a spin and the handling was great except the fact that the car actually bounced along the road as a cartoon car would. I think it could possibly be the rear air-ride shocks, of course they are shot b/c their 40 yrs old, but I'm not entirely positive if that will fix the problem. Any suggestions?
Old May 2, 2007 | 02:50 AM
royal68's Avatar
royal68
Default RE: Bouncy Ride
one test - when parked/engine off, push and pull up and down on a corner of the car a few times thenlet go- the car should settle pretty quick, if it bounces more than once or twice you probably need new shocks
and since yours are 40 yrs old, you need new shocks
Old May 2, 2007 | 02:54 AM
restomod@16
I have done the "bounce" test and the results are fine. I changed to a front coilover suspension. Is it just a matter of breaking in the new leafs/ front coilover shocks?
mat11089's Avatar
mat11089
Its a shame that you replaced everything else and left the old shocks.Replace them youll be greatful.
Old May 2, 2007 | 03:04 AM
Aussie66Fastback's Avatar
Aussie66Fastback
was there a reason you left the old shocks in the back?
if you have new springs that are reasonably firm, the bounce test may be a little misleading and more than likely your rear shocks are the problem.
depending on the spring rates etc and what shocks are included with the coil over fronts, the ride should be pretty firm, which mayskip the rear of car arounda little over a rough surface, but not a sloppy bounce.
Old May 2, 2007 | 03:11 AM
restomod@16
ya i really wish i had changed them at the same time. Its ok not hard to fix at all. I really hope it works tho
Old May 2, 2007 | 03:28 AM
connor90's Avatar
connor90
im glad you brought this up because mine is the same way except its only bouncy in the back so when your dirving it feels like the back is going to come out on you
Old May 2, 2007 | 04:37 AM
Aussie66Fastback
I probably went too far the other way...now it is like a rock on the back...no bounce to test even with full body weight thrown down on it, but it means it will dance around on the back if you hit rough patches on the road.
quite scary if you are punting hard and mid corner[]
Coyote_hpr
Nov 12, 2019 12:44 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
1Bad71
Sep 30, 2015 07:37 PM
treesloth
Sep 28, 2015 07:03 AM
Sep 27, 2015 03:16 PM
