dash lights
Old May 2, 2007 | 01:31 PM
mac66's Avatar
mac66
Default dash lights
I have a stock 66 mustang coupe. Problem is I have no dash lights. Turn indicators work, high beam indicator works and courtsy lights work.
I have detirmined that my constant voltage regulator is cooked, would the effet my dash lights? If not what would be the problem? Yes all bulbs are good.
Old May 2, 2007 | 02:10 PM
66GTKFB's Avatar
66GTKFB
Default RE: dash lights
There is a 2.5 amp fuse in the fuse panel that protects the wiring from short circuits. Replacing the fuse would be the first thing to do. If it blows again, you got a wire shorted to ground. The constant voltage regulator only provides low voltage to the fuel and temperature guages, and nothing to do with thelights.
Jim
Old May 2, 2007 | 02:14 PM
Cogtx's Avatar
Cogtx
Had similar prob with a 67 coupe and no dash lights. After replacing bulbs, checking fuses, etc. the solution was to clean the contacts on the light switch itself. Everything worked after that. You may need to clean the light switch or replace but do the fuse check first...good luck...
Old May 2, 2007 | 06:50 PM
mac66's Avatar
mac66
Fuses are good, so are the bulbs, I bought a new light switch so I will replace that and see what happens.
Old May 2, 2007 | 06:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
After you turn your lights on, twist the **** on the headlight switch. There is a built in dimmer on the switch so you can adjust the brightness of your gauge lights at night.
Old May 2, 2007 | 07:03 PM
mac66's Avatar
mac66
Been there, done that, thats why I bought the new switch...
I hope that it works.
If not I'll be here tomorrow.....
folivier
Oct 2, 2015 05:34 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Sep 25, 2015 09:06 AM
accarter
Sep 21, 2015 11:56 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
