Accelerator Rod
Old May 3, 2007 | 04:11 PM
sxs191's Avatar
sxs191
Default Accelerator Rod
Can someone please show me what the correct acceleratorrod (going from the accelerator pedallinkage to the carb) looks like for the '68' 302, please? I can't find them for sale and the one I have appears to be forthe wrong engine.. (this one)http://www.mustangsunlimited.com/ite...sp?T1=69772+01
Itworked on the Autolite 2100 I had but now that I'm going to a Holley Street Avenger 570cfm and I don't think it'll work and I need the correct part. Thanks, Scott
Old May 3, 2007 | 04:18 PM
dodgestang's Avatar
dodgestang
Default RE: Accelerator Rod
While it might not be the answer you are looking for....
Threaded rod and little 90 degree fittings from McMasterCarr work excellent for creating your own custom legnth accelerator rod.
Old May 3, 2007 | 04:33 PM
sxs191's Avatar
sxs191
Great thanks. Is yours fully threaded 5/16"-24?
Old May 3, 2007 | 04:41 PM
sxs191's Avatar
sxs191
What did u use for the end pieces? I can't find anything listed under 90 degree fittings...UGH. Thanks
Old May 3, 2007 | 04:46 PM
dodgestang's Avatar
dodgestang
"Ball joint shielded linkages"
I did not use a fully threaded rod...I bought a couple different lengths but I forget which one I acutally used.
Old May 3, 2007 | 04:48 PM
dodgestang's Avatar
dodgestang
This pic might show it better:
The rear is attached with a "Ball joint shielded linkages" and the front attached to the carb with a spring loaded quick on and off linkage. All of it was from Mcmastercarr. Simply browse through 'linkages' and I think you will find everything you need. That's what I did
Old May 3, 2007 | 05:20 PM
sxs191's Avatar
sxs191
I will do that. Thanks again.
Old May 3, 2007 | 05:28 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Here is a link to a slick setup I used on my fastback.
http://www.fordmuscle.com/archives/2...kage/index.php
Old May 3, 2007 | 07:33 PM
19stang66's Avatar
19stang66
^^ thats the one i'm going to make for my holley.
jrrhd73must
Oct 2, 2015 09:17 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
UrS4
Sep 30, 2015 10:13 AM
mustangheaven
Sep 29, 2015 11:00 AM
gagemcc
Sep 22, 2015 09:43 AM
