shock tower repairs help needed!!!
Old May 4, 2007 | 01:22 PM
stangimgood's Avatar
stangimgood
Default shock tower repairs help needed!!!
added new wider tires to front..now tire rubs when backing up and turning left...does not do this driving forward..i noticed that the shock tower is showing a gap on the front edge of the plate on the inside of engine bay...i read somewhere about the procedure to push the a-arm back in the proper position and weld the area, but can not find it in the archives.. anyone know how to "properly" push the area back in position to weld? please help me...wife gets cranky when she can't drive her car!!!
Old May 4, 2007 | 05:35 PM
woodywrkng's Avatar
woodywrkng
Default RE: shock tower repairs help needed!!!
My car has had both its towers rebuilt. One by a welding shop, the next by a body man who had made templates since he's done this repair several times. If you don't get the towers done right, you won't be able to align the front end properly, so maybe seek out a bodyshop that's familiar with it.
Old May 5, 2007 | 08:59 AM
stangimgood
was hoping to do myself...there are not a lot of places in my area that i would leave our car with for this type of repair...besides i love to do my own work....35 years of screwing around with cars and not afraid to do anything on them...besides..if i screw it up ..i can always have it done then....so any help from anyone else??? soaring...any input?? thumpin??
Old May 5, 2007 | 09:22 AM
latamud's Avatar
latamud
Rubs in reverse but not in forward, is there a clunking noise just before you start moving? I ask because I had an alignment shop NOT tighten one of my upper control arm mounting bolts one time. The Shims on the forward bolt fell into the cuped area under the arm, top of the frame rail. Everytime I went into reverse the I heard the clunking noise, and the upper arm moved forward changing my caster. Then when going forward, the arm moved back until the nut caught on the shock tower in the engine compartment side. It comes to mind because you say it rubs in reverse but not in forward. Sounds like there is some play somewhere.
Old May 5, 2007 | 09:31 AM
stangimgood
no problems with any part of the suspenion...all new, replaced myself...and it was the first thing i checked..with hood off you can watch it gap at the area on the tower where the formed plate meets the tower sheet metal....i had wife drive while i sat on front to watch...(her chance at life insurance $ and she blew it) but thanx for input....anyone else????
Old May 5, 2007 | 11:18 AM
Soaring's Avatar
Soaring
I ♥ Acer
Since my towers are right where they should be, I will go out this afternoon and take some measurements so you will know where to put yours. In the meantime, here is a kit that you can buy and weld these pieces to your tower for strength. Just a thought.
http://www.cal-mustang.com/showdetl-7-6383-19-0.html
Old May 5, 2007 | 02:14 PM
66GTKFB's Avatar
66GTKFB
Get a Ford Service Manual for your car, it looks like a 65 or 66. There is a section on frame alignment with dimensions. I've seen in NPD, the entire engine compartment sides, from firewall to radiator support, for sale, about $530. That may be a more practical solution for your problem. Remember, the VIN number goes away withthat new sheet metal.
Jim
Old May 6, 2007 | 08:56 AM
stangimgood
soaring i have looked at that kit...seems that is prob. the way to beef up the area but need to put the tower plate back first...66TKFB i have the manual also....however i know i read somewhere about a way to get the tower "jacked" back to proper position...i thought it was here on this forum someplace...i was hoping someone may know where ormaybe i read someplace else...must have been elsewhere.... i do thank everyone for the input and i guess i'm off to look for the info.....thanx don
drfister
May 3, 2018 10:38 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
chrisdbassplayer
Sep 1, 2015 05:30 PM
motown girl
Aug 28, 2015 08:21 AM
defarmer
Aug 13, 2015 06:40 AM
