Carb mucked up?
Old Dec 28, 2004 | 07:55 PM
69mach1377's Avatar
69mach1377
Default RE: Carb mucked up? Update!
Well... that's what happens when your MSD ignition has never failed, but your carb has or a valve has gotten stuck...fear of recurrance.
Ignition failure results in the engine stops running, valve stuck can lead to more costly consequences...
Old Dec 28, 2004 | 08:56 PM
Stanley's Avatar
Stanley
As long as you don't check for spark right after you were messing with the carb you should be ok.
Just make sure you didn't spill any gas anywhere.
gas fire in the engine compartment = bad
Old Jan 4, 2005 | 06:31 PM
69mach1377's Avatar
69mach1377
Weekend update...no fires.
Good spark from coil to distributer and the power valve is now verified to be good. Changed out spark plugs...MSD does not like platinums. Ran a little better but noticed #4 not firing consistently. Ordered new cap, rotor and wires for next weekend. I guess they were due after 6 years plus...getting the super conductors.
I'll chase it down sooner or later.
Old Jan 9, 2005 | 03:14 PM
69mach1377's Avatar
69mach1377
Default RE: Carb mucked up? Not!!!!!!!
Kind of embarassing...all it needed was a tune up! Cap, rotor and wires did the trick...actually used older plugs. What tricked me I think was that the symptoms appeared during a casual drive and progressively got worse as I chased down other more complicated probable causes. Goes to show you/me...KISS!
Old Jan 9, 2005 | 03:53 PM
tornado's Avatar
tornado
so all it needed was a tune up eh.... it suck u had to go through all that other sh** but at least u got ur car running
Old Jan 10, 2005 | 07:06 PM
horseshoeing's Avatar
horseshoeing
With the high power MSDs they will do funny things thats for sure.
Old Jan 10, 2005 | 11:13 PM
69mach1377's Avatar
69mach1377
Well the big clue was the huge spark that came out of the coil and poor spark to the plugs.
At least all the other stuff is good to go for a while.
This is what happens when your other car and truck are diesel, what spark plugs, etc....
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
