tech question
Old May 8, 2007 | 03:03 AM
valley firearms's Avatar
valley firearms
Default tech question
This question came from my Mom's boyfriend:
[/align] Sat. I shifted out of low at 4000 then the engine started popping through the carb. It does that while under load, but cruising up the street at 25-30 mph in high, it was smooth. any ideas?
I think the car (67 cougar) is starving for gas (secondaries). What do you all think?
[/align]
[align=left] [/align]
Old May 8, 2007 | 09:41 AM
dodgestang's Avatar
dodgestang
Default RE: tech question
Spark plug firing while intake valve is still open.
Worn out valve springs that can't close fast enough anymore - maybe
Worn out valve that doesn't seat all the way - maybe
Too far advance timing causing the plug to fire before the valve is closed - common
Poorly adjusted/loose rocker arm - my bet
Old May 8, 2007 | 10:07 AM
Soaring's Avatar
Soaring
I ♥ Acer
It wouldn't be firing if it was starving for gas. Sounds like he needs a valve job.
Old May 8, 2007 | 11:31 AM
19stang66's Avatar
19stang66
"What's a ZJ? If you have to ask you can't afford one"
ahh sh*t I thought valve job was zj instead of vj. you old farts wouldn't figure out the quote anyways. [8D]
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
