Lost
Old Dec 15, 2004 | 08:56 PM
jrparatrooper's Avatar
jrparatrooper
Default Lost
Yo!
hows everyone?.......I just got my hands on a 66 mustang 289 one owner all original......and its in pretty good shape!
however, it wont start. I hooked up the jumper cables to give it a jump.....turned the key and all I got was a kinda winding sound...that sounded like it was comming from the starter engine.
The battery is in good shape, I changed out the solinoid and its still making the same "wiiiiiiieeen" when I try and start it. Nothing in the engine is moving when this is happening, so I think it may be my starter.
anyone have any good opionions as to what may be wrong, before I go buy a new starter, if I dont have to.
Thanks
Don
Fayetteville, NC
Old Dec 15, 2004 | 11:11 PM
rwcstang's Avatar
rwcstang
Default RE: Lost
yeah it should be the starter i had the same problem, when i started mine up one day it started doing the whining thing, so i changed the starter, and wa-la starts a growls like a lion. lol
[IMG]local://upfiles/6730/5F34E838429442B2AA724A74661DFAB7.jpg[/IMG]
Old Dec 16, 2004 | 10:59 AM
69FECoupe's Avatar
69FECoupe
Default RE: Lost
Make sure you check to make sure there are no broken or missing teeth on the flywheel.
Old Dec 16, 2004 | 12:25 PM
horseshoeing's Avatar
horseshoeing
Default RE: Lost
Take your starter to a starter shop! Let them test it for you.
Old Dec 18, 2004 | 12:11 PM
jrparatrooper
Default RE: Lost
Turned out it was the starter.....it wasnt engageing the flywheel!
I took it off, took it apart.....then realized that maybee, just maybee it was due to the fact that the bottom bolt holding the starter on the car was finger loose..............and that maybe the starter was fine, just not fully installed.
well that was it, put it back together, installed it...tight this time and it fired right up.........
now i have smoke comming in my vents when i turn on my heat
Old Dec 18, 2004 | 08:02 PM
me alot fast than u's Avatar
me alot fast than u
I ♥ Acer
Default RE: Lost
starter shop?*L*..dude you can pull it out and hook jumper cables up to it to see if it works...man I bet shops love you..do you even change your own oil??
Old Dec 18, 2004 | 11:53 PM
roundman's Avatar
roundman
Default RE: Lost
ORIGINAL: jrparatrooper
hate to tell you this but now you've got a leaking heater core and that smoke is antifreeze which will really f**k up your visibility through the windshield. temp quick fix is to bypass the heater core with the heater hoses until you get the time to pull it out and get a new one. just connect the two hoses to each other after taking them loose from the heater.
Old Dec 20, 2004 | 09:32 AM
horseshoeing
Default RE: Lost
"starter shop?*L*..dude you can pull it out and hook jumper cables up to it to see if it works...man I bet shops love you..do you even change your own oil?? "
They don't charge me anything to test a starter. They must see you coming
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
foxdude
Sep 24, 2015 08:45 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
