oil pan
Old May 10, 2007 | 12:37 AM
white69mach1's Avatar
white69mach1
Default oil pan
what do yall think about this oilpan http://store.summitracing.com/partde...p;autoview=sku does it seem like a ok deal
Old May 10, 2007 | 12:58 AM
1rareX's Avatar
1rareX
Default RE: oil pan
Welcome to Mustangs Plus on the Web! Your Mustang Parts Source!you can get a similar setup here for Pan Kit $159.95
Windage Kit$124.95
About 284.00 plus shipping
Good Luck , Bill
Old May 10, 2007 | 01:01 AM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: oil pan
mighty fine
you looking to buy one?
what do you use your car for?
Front sump engines without baffles always suffer from potential pickup problems on road circuit or drag strip, so if you are going racing its a good idea!
white69mach1
Default RE: oil pan
i will be street and drag mostley street tho it says stroker clearance no so i guess that mean it want work with a stroker
Old May 10, 2007 | 01:10 AM
6marc5's Avatar
6marc5
Default RE: oil pan
I like it
Old May 10, 2007 | 01:14 AM
white69mach1
Default RE: oil pan
i think i might go with this one instead http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old May 10, 2007 | 02:29 AM
Aussie66Fastback
Default RE: oil pan
ORIGINAL: white69mach1
i read it slightly differently...depends on the stroker kit. I'd bet there is another windage tray available for the stroker engines and that sump anyway
tha Canton one you posted last is a rear sump...no good for your 69
Old May 10, 2007 | 02:50 PM
jspagna1's Avatar
jspagna1
Default RE: oil pan
I would go with the Milodon 8 qrt pan. The more oil the better. I have had one on my motor since day one and no problems,no leaks.
Old May 10, 2007 | 04:33 PM
atomsk680's Avatar
atomsk680
Default RE: oil pan
i have a chrome ford racing one
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
