Engine turns over but won't start
Old May 11, 2007 | 07:37 PM
solidGas's Avatar
solidGas
Default Engine turns over but won't start
Hey,
This is the first time I haven't been able to start my Mustang, and I feel pretty dumb, it usally starts right up. I am a little green when it comes to engines so any help would be appreciated.
I am trying to start the Mustang up and it will turn over but it wont start. What should be the first thing I should look at?
I have a 289, stock 4100 carb, and my distributor has points, but they look new to me. I am also at work and only have a screwdriver and a crescent wrench.
Thanks in advance.
Old May 11, 2007 | 07:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Engine turns over but won't start
The first thing I would check would be to make sure the coil wire is all the way into the coil and the dizzy. When my son was a senior in high school he was to big to spank, so if he screwed up, I would just take his coil wire. He got tired of walking to school, so didn't screw up any more.
Then check your points if you still have them to make sure they are not burned.
Old May 11, 2007 | 07:56 PM
P Zero's Avatar
P Zero
First thing I would check is for a choke that is stuck closed. The flap on top of the carb should be slightly open. If its not, on a warm day the car WILL NOT start and flood really bad. Its actually a really simple fix, take off your air cleaner, use a pen to open that flap up (you might have to leave the pen in the carb while youre trying to start it). Then simply hold the pedal to the floor and crank it up.
-P.
Old May 11, 2007 | 08:05 PM
solidGas's Avatar
solidGas
Ok, I will check the coil and the points and also look at the carb's choke. I have to wait a couple hours till most people leave the office building, I am parked right in front. Kinda embarrassing having to get under the hood in front of all the other business owners in the complex.
Is there anything else I should look for, while I am out there?
Old May 11, 2007 | 08:19 PM
Mustangdemon67's Avatar
Mustangdemon67
if not the points it may be the condensor, or ignition wiring.
unplug the wire from the top of the coil and have someone hold it over something metal, and then try to start it and see if there is a spark, if not then its your points or condensor. that spark test is too see if your geting power relayed from the distributor.
Old May 11, 2007 | 08:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Look down the venturi of the carb and manually work the throttle to see if you are getting gas squirted into the carb. Look at your gas gauge. Is it on E?
Old May 11, 2007 | 09:07 PM
hellion_79's Avatar
hellion_79
ignition switch could be out. To check, take a *screwdriver* and connect the positive connection to the upper starter connection. If you did this right the motor will turn over and make sure your key is turned all the way before you get into the starting the car and then try the solonoid trick. If you cant find it, the positive *red* wire from the battery should lead right to it. Tell me what happened after you tried this.
Old May 11, 2007 | 09:30 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: hellion_79
Hey fruitcake, do you mean to short across the solenoid with the key in the on position to see if the solenoid is bad? The engine is turning over so that can't possibly be the problem. Go back to sleep.
Old May 11, 2007 | 09:41 PM
hellion_79's Avatar
hellion_79
ORIGINAL: Soaring
Yah I know that[8D]But my car when I turned the key it would turn over but wouldnt start, but when I touched the connections it fires right up which mean....... my ignition switch was bad or shorted out. After I replaced it, that problem went away.
Old May 11, 2007 | 09:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
The connections where? Are you talking about hot wiring where you route around the ignition switch?
