weak springs
Old May 11, 2007 | 08:51 PM
ty4my66's Avatar
ty4my66
Default weak springs
The rear end on my 66 sits a little lowmy question is would airshocks fix this until i can get around to putting a new set of springs under it?
Old May 11, 2007 | 08:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: weak springs
No. A classic mustang can not handle air shocks as the area on the top of the shock is thin and you will punch through if you air up the shocks and hit a bump. Shocks on any vehicle should never be used to support the weight of the car. That is not their intended purpose. Just go ahead and replace the leaf springs with new ones and put on a set of KYB gas adjust shocks. Otherwise, just put up with the butt sagging until you can afford the new leaf springs.
Old May 11, 2007 | 09:11 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: ty4my66
Your best option would be a leaf spring airbag system but they're not cheap.
http://www.ridetech.com/wizard/results.asp
Just do a vehicle search for your options.
Old May 11, 2007 | 09:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Derf00
ORIGINAL: ty4my66
Nah, the air bags are not necessary. Just a new set of leaf springs will bring it back up to factory specs.
Old May 11, 2007 | 09:33 PM
connor90's Avatar
connor90
Stay away from air shocks. Like Soaring said, just get new leafs and shocks and you'll be all set.
Old May 11, 2007 | 10:07 PM
JamesW's Avatar
JamesW
...and besides...Gabriel Hijackers would cost you $100 to install a pair. New Leaf Springs will cost you about $130.
Old May 11, 2007 | 10:25 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JamesW
Good point Jimmy. Now, are we going to have to go into the how to get out the front bolt again?
Old May 11, 2007 | 10:38 PM
68FastbackGT's Avatar
68FastbackGT
ORIGINAL: Soaring
Man do I feel stupid. That explains the stress fractures in the sheet metal around where the rear shocks attach to my car. I had installed air shock when I was a teenager for this very problem.
Old May 11, 2007 | 11:14 PM
ty4my66's Avatar
ty4my66
where do i get the springs for 130.00?? AllI have seen are 199.00 and up for the pair.
Old May 11, 2007 | 11:25 PM
Bentworker's Avatar
Bentworker
Springs are not that hard to install. You can swap them out in a few hours, stay very far away from air shocks...
1)Spray the hell out of the front eye bolt, shackles, and U-bolts with Pen-10, liquid wrench or any good penetrating oil, and let sit for a day or two.
2)Break loose you U-bolts while the car is on the ground.
3)Break loose your rear lug nuts.
3)Support your car with quality jack stands (place them in front of the front spring eyelet). Use chocks on your front wheels!
4)Remove the rear wheels.
4)Break loose the front eyelet bolts, and the shackles.
5)Support one side of your rear axle with a jack ( do not allow the axle to be supported by the brake hose!)
6)Unbolt lower end of shock.
7)Remove U-bolts on side that is supported.
8)Remove shackle and allow spring to pivot on front mount then rest on ground.
9)Remove front eyelet bolt, then remove spring.
Install in reverse, then move to the other side.
This method seems to be the easiest for me, it does not require wrestling the spring too much (they are HEAVY) I like it because you only have to hold up one end of the spring at a time.
If you have a high horsepower setup you may want to look at the Maier Racing springs, they have a bunch of leafs in the front of the pack that keep it from wrapping up and prevent wheel hop, like a tractionbar but better.
