weak springs
Old May 11, 2007 | 11:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: weak springs
ORIGINAL: Bentworker
Springs are not that hard to install. You can swap them out in a few hours, stay very far away from air shocks...
1)Spray the hell out of the front eye bolt, shackles, and U-bolts with Pen-10, liquid wrench or any good penetrating oil, and let sit for a day or two.
2)Break loose you U-bolts while the car is on the ground.
3)Break loose your rear lug nuts.
3)Support your car with quality jack stands (place them in front of the front spring eyelet). Use chocks on your front wheels!
4)Remove the rear wheels.
4)Break loose the front eyelet bolts, and the shackles.
5)Support one side of your rear axle with a jack ( do not allow the axle to be supported by the brake hose!)
6)Unbolt lower end of shock.
7)Remove U-bolts on side that is supported.
8)Remove shackle and allow spring to pivot on front mount then rest on ground.
9)Remove front eyelet bolt, then remove spring.
Install in reverse, then move to the other side.
This method seems to be the easiest for me, it does not require wrestling the spring too much (they are HEAVY) I like it because you only have to hold up one end of the spring at a time.
If you have a high horsepower setup you may want to look at the Maier Racing springs, they have a bunch of leafs in the front of the pack that keep it from wrapping up and prevent wheel hop, like a tractionbar but better.
That all sounds wonderful bentworker, but you forgot to mention that the front bolts are rusted to the collar so have to be cut off. I used a sawzall.
Old May 12, 2007 | 02:29 AM
67mustang302's Avatar
67mustang302
Mine weren't rusted. Well, they may have been, but I just used my high priced IR 1/2" drive impact gun. It drives out with 600ft-lbs of torque, so if they were rusted, I never felt it.
Old May 12, 2007 | 02:38 AM
mat11089's Avatar
mat11089
if u have an airhammer put the pointed tip on and it pops right out.my dad and i spent a couple hours before i walked by the toolbox and said lets try this.took less than a min then.
Old May 12, 2007 | 09:41 AM
ty4my66's Avatar
ty4my66
Wheres the $130.00 springs at?
Old May 12, 2007 | 11:47 AM
JamesW's Avatar
JamesW
$109.95...I estimated the rest for shipping..may be higher
http://www.parts123.com/parts123/yb....Z5Z5Z50000081b
Old May 12, 2007 | 11:56 AM
Soaring's Avatar
Soaring
I ♥ Acer
Texas Mustang out of Waco is where I got mine. Damn good springs.
Old May 13, 2007 | 05:51 PM
ty4my66's Avatar
ty4my66
would you get the 3 or 4 leaf it does have a 6cyl in it.or would the 4 leaf make it to tall?
Old May 13, 2007 | 05:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, you need the 4 leaves. I don't even know if you can buy a 3 leaf spring for a classic mustang. The rear end of that car is just as heavy as a V8 car.
Old May 13, 2007 | 09:47 PM
JamesW's Avatar
JamesW
ORIGINAL: Soaring
Same here... and it's convenient having them 5 miles from the house....
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
