Cylinder heads
Old May 12, 2007 | 06:01 PM
paddy187's Avatar
paddy187
Default Cylinder heads
Ok got my car back from my mechanic with new dual master cylinder, annual safety check reveled it need two new lower control arms but she is now running better than beforeso very happy, but the mechanic says the cylinder heads need rebuilding in 1-3k miles.My question is when this occursI thinkI will upgrade the intake and add a new carb at the same time and so whatpackage (heads intake carbs)do people recommend? And what also would be worth doing at the same time? What year explorers should i look for and what other than the heads should I remove from the explorers?
Old May 12, 2007 | 06:15 PM
350kmileFord's Avatar
350kmileFord
Default RE: Cylinder heads
If you want something proven and easy to order, I'd recommend something like this:
http://store.summitracing.com/partde...p;autoview=sku
Granted, you need to replace your cam, but you'll notice such a difference!
Old May 12, 2007 | 07:03 PM
my77stang's Avatar
my77stang
for ease of header/spark plug issues, look for a 97 1/2 or older explorer. you dont need anything other than the heads and rocker arms. i'd run with a performer rpm airgap or even a regular performer rpm (or maybe one of them thar wieand intakes)
Old May 12, 2007 | 07:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
If I ever have to rebuild my 289 it's going to get gt40 heads a weiand dual plane intake and a Motorcraft 4100 carb.
Old May 12, 2007 | 07:48 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
gt 40 heads are great but they don't just bolt on fyi they have 64cc chambers on them vs the 54cc on your 289/302 so that will really hurt the power of your car cunless you mil them down but wouldn't that change rocker arm geometry so you would have to get diff pushrods am i right
Old May 12, 2007 | 08:00 PM
arthur's Avatar
arthur
hey Paddy,
have you been to that guy you recommended for that engine?
was it a good experience there?
arthur
Old May 12, 2007 | 10:25 PM
my77stang's Avatar
my77stang
brandon is right, but getting the heads milled is no big deal, and neither are shorter pushrods
Old May 12, 2007 | 10:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Oh. the heads would be milled for sure and valves ground/replaced, etc. I just can't see spending close to 2K for heads when you can get some gt40's at the junk yard for a fraction of that cost. I wouldn't be building a hot rod anyway. I would just be trying to make an A code of of the C. But, for many years to come, she will remain a C and haul me around just fine.
Old May 12, 2007 | 11:27 PM
connor90's Avatar
connor90
uh oh soaring....you better be careful, your car is getting closer and closer to becoming that slayer.
Old May 12, 2007 | 11:34 PM
19stang66's Avatar
19stang66
don't explorer heads need different manifolds or headers? I think that also goes for certain gt40 heads. Correct me if i'm wrong.
