200 to a 289 conversion
Old May 13, 2007 | 02:10 PM
mr.tinman's Avatar
mr.tinman
Default 200 to a 289 conversion
hello everyone, i got a few questions to ask about this to make sure im not making a huge mistake...
my original idea was to put in an already carburated 302 from an 89 5.0 into my 66 coupe. I kept reseacrhing and came to the conclusion (after i had bought the 5.0) that it would just be too expensive for me. I wanted to know if it would be a better idea to put a 289 in there and still be able to use my same transmission ,rear end , brakes, and suspension that came with the 200ci?
i was planning on buying the remanufactured engines from cjpony.
i really appreciate any help, thanks
Old May 13, 2007 | 02:44 PM
paddy187's Avatar
paddy187
Default RE: 200 to a 289 conversion
you can use the same transmission, rear end, brakes and suspension but your car will either kill you or just fall apart. You need those all things changing, if money is an issue do those things first the worry about the engine
Old May 13, 2007 | 04:48 PM
mat11089's Avatar
mat11089
Nope if you change from a 6 to and 8 everything else in the entire car must follow suite.Itd be better to sell and buy and 8 or drive you 6 and be proud of it
uberstang1
Dec 7, 2017 07:10 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
