Mold On or Bolt On Side Scoops?
Old May 13, 2007 | 06:41 PM
Shifty101Easy's Avatar
Shifty101Easy
Default Mold On or Bolt On Side Scoops?
what is a better choice???
http://cgi.ebay.com/ebaymotors/side-...mZ300111071482
i want to pull the trigger on those right now but dont know much about molding stuff on...do i just use some kitty hair or something?
Old May 13, 2007 | 08:31 PM
valley firearms's Avatar
valley firearms
Default RE: Mold On or Bolt On Side Scoops?
Best thing to do would be to ask a body shop. Don't use putty as it will crack all the way around the scoop after the car is painted. I have never used kitty hair but I hear thats the bomb for doing stuff like that. I used the bondo glass and haven't had any problems yet. Whatever you use, apply the least amount as possible.
[align=left] [/align]
Old May 13, 2007 | 08:52 PM
Shifty101Easy
im wonder if i could just add my own bolt and then make them bolt ons?? i mean they just use kitty hair to do the quarter panel extentions dont they??? same thing as far as i can tell?
Old May 13, 2007 | 09:03 PM
67SuperSnake's Avatar
67SuperSnake
Bondo or even kitty hair (fiberglass) can crack over time.
Do like the corvette guys have done for years. Get a good bonding agent and you will never have any problems.3M makes a good one8115 for fiberglass to metal.
Old May 13, 2007 | 09:52 PM
Shifty101Easy
oh good idea...i wonder if there is a flange to put the bonding agent on...?
Old May 13, 2007 | 10:25 PM
67SuperSnake
I don't know how different those scoops might be, but you grind the edge a little to give you more of a flange. I had already used self drilling/tapping screwsto mountthe scoop in place before Ibonded it.Remove it, then you add a liberal amount of bonding agent. I used the same screws to hold it in place while the bonding agent set up. I used a 90 minute cure bonding agent. Gives you enough time to get itwhere you want it.
Old May 13, 2007 | 10:28 PM
67SuperSnake
Results:
Old May 13, 2007 | 11:09 PM
valley firearms
The one's I purchased off e-bay did have one stud on each of them. I added one making for a total of two. I had to do so to suck the back of the scoop to the quarter. After I fit the scoops to the quarter panel I filled the scoop from the backside with urethane foam to bond it to the quarter panel. Then I used bondo glass to blend the edges in.
Old May 13, 2007 | 11:43 PM
Shifty101Easy
ORIGINAL: valley firearms
is bondo glass essentially kitty hair....fiberglass body filler?
maestro1024
Sep 21, 2015 02:40 PM
trashxtrash
Sep 20, 2015 10:49 PM
ctgreddy
Sep 20, 2015 08:35 PM
zachary1988
Sep 18, 2015 11:17 PM
GentleBen
Sep 11, 2015 05:34 AM
