Overheating problems.
Old May 16, 2007 | 09:37 AM
andrewmp6's Avatar
andrewmp6
Default RE: Overheating problems.
heres my questions do you have a overflow and how many pounds is the radaitor cap
Old May 16, 2007 | 10:00 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Aussie66Fastback
i disagree BT!
the thermo will open wide at the given temp, plus or minus a few degrees. If its a cold day, it'll close down to restrict flow to maintain that temp.
if your rad isnt workign properly orits really hot weatherit will open wide and have no bearing on the temp at all.
badazz it might be worth trying a different gauge. you didnt say if you had teh rad cored or not.
if it is mild weather and all the system is working properly,temp should not rise in trafficcompared tocruising. If it is hot, then fair enough, but i'm talking into the 90's.
On the contrary my Aussie friend. A thermostat does not go from completely closed to completely open in one action. As the wax melts, the thermostat slowly opens, allowing more and more water to enter the engine as the engine heats up. Here, take a read.
http://auto.howstuffworks.com/cooling-system8.htm
Old May 16, 2007 | 12:28 PM
Gun Jam's Avatar
Gun Jam
true (as I think I mentioned in a latter post) but I would think that at 205 a 160 would be wide open. And really there is nothing wrong with running at 205 which is just a tich above dead center normal. If it maintains those temps at 50 and at 80mph and can do it during summer he should be set to go.
Gun
BOB ROME
Jul 26, 2023 01:54 PM
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
MusicCity615
Sep 12, 2015 07:05 AM
zanemoseley
Sep 6, 2015 12:58 PM
