Tire size
Old Dec 19, 2004 | 06:27 PM
gizahuna's Avatar
gizahuna
Default Tire size
I have a set of magnum 500 styled rims size 15" x 7". What is the proper tire sizing for a 68 coupe?
Old Dec 19, 2004 | 06:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Tire size
I'm surprised DodgeStang hasn't chimed in with his chart. But, here it is, and all the credit is due to DS. http://www.dodgestang.com/Tire%20Fit...ide%2067-8.pdf
Old Dec 19, 2004 | 07:08 PM
gizahuna's Avatar
gizahuna
Thanks...that chart is great!
Correct me if I'm wrong. The maximum tire size I could go with my car is 225/60R15. But I could go smaller in tred width, maybe 215 or 205) right? Or is this size the size I shoud get? I'm not looking to race the car. It is basically a Sunday car with my kids?
Old Dec 19, 2004 | 08:34 PM
import slayer's Avatar
import slayer
You could get 245/60/15 on there if you wanted to but to answer your question, yes, you can go with a 215 or 205 tire.
What mustang are those rims from? The '68 mustangs only can with 14" rims unless it was the shelby which got the E70-15 tires.
Old Dec 19, 2004 | 08:56 PM
dodgestang's Avatar
dodgestang
ORIGINAL: gizahuna
Depends ALOT on the backspacing of the rims and what brakes you are running.
Assuming you have the stock drums, a 215 will work just fine for you with the assumption that the Magmun 500s have a 3.75 backspacing.
Old Dec 19, 2004 | 10:26 PM
gizahuna's Avatar
gizahuna
I have drum brakes all around and the backspacing of the mags is 4-1/4".
Old Dec 19, 2004 | 11:12 PM
dodgestang's Avatar
dodgestang
The you can go up to a 225 for sure without a problem.
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
M3hunter
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
