351W
Old Dec 17, 2004 | 02:03 PM
Baddog079's Avatar
Baddog079
Default 351W
How much HP does a normal/stock 351W make? I'm putting one down in my 67...
Old Dec 17, 2004 | 02:09 PM
georgiabadger's Avatar
georgiabadger
Default RE: 351W
4v came from the factory rated @ 290 Gross
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: 351W
most around 150 - 180 hp, about 300 lbs torque. their dogs from the factory - need a cam to wake em up. can easily get 350 - 400 hp out of descent heads, cam, intake, carb.
Old Dec 17, 2004 | 02:15 PM
angcobra's Avatar
angcobra
Default RE: 351W
At the flywheel I have seen them posted as low as 177 (2v) but most were 250 to 290.
Old Dec 17, 2004 | 02:23 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: 351W
you can't go by the factory ratings, they were rating differently back then
Old Dec 17, 2004 | 02:39 PM
69mach1377's Avatar
69mach1377
Default RE: 351W
Yeah...they had smaller horses back then
Old Dec 17, 2004 | 02:59 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: 351W
they didn't use the SAE standard until the 70's, before that rated hp was done with no accessories or exhaust on an engine dyno. On average the new SAE method showed about 20% less then the "old" way. Sometimes it was even more than that. Also, I suppose it matters what year and what the 351w came out of - as their differently setup thooughout the years and vehicles used in.
Old Dec 20, 2004 | 12:00 AM
tinman's Avatar
tinman
Default RE: 351W
These 351W's can make 375-400 H.P. pretty easy even using some stock head castings and doing some bigger valves and a little work in the bowl areas with a grinder. The GT40 heads seem to be getting cheaper all the time so I think that would even be a better way to go. The 351W also uses a much longer rod than most engines in that size catagory and that helps make torque. You can use more duration in the cam than a 302 due to the longer stroke......
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
FoxGT
Jul 11, 2004 11:49 PM
Mustang88LXKid
Feb 29, 2004 08:01 PM
WNDSOR
Jan 30, 2004 09:47 AM
