transmission issues
Old May 16, 2007 | 03:19 PM
66_grn_fstbk's Avatar
66_grn_fstbk
Default transmission issues
Hey guys,
At high speed occassionally my automatic will drop down to second gear from drive. It is pretty scary at 70 miles an hour. I was wondering whether anyone has an idea about why, and what the fix might be?
cheers
Old May 16, 2007 | 07:56 PM
66JameStang's Avatar
66JameStang
Default RE: transmission issues
I drove a 1990 pick up for a while and the truck would do exactly what you are describing and if it is like mine it becomes worse with fewer amounts of time in between. i ended having to take my truck and get the transmission rebuilt and it worked fine after that. it is caused from wear and tear or from nuetral drops.
Old May 16, 2007 | 08:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Try tightening the bands and see if that helps. That how-to is in the FAQ under transmissions.
Old May 17, 2007 | 12:27 AM
TheDrivenMan's Avatar
TheDrivenMan
You could always convert to a 5-speed and get rid of the auto. I am kinda biased since I work with these conversion all the time, but there is nothing like shiftin' it yourself.[8D]
Old May 17, 2007 | 12:52 AM
connor90's Avatar
connor90
it might have something to do with the vaccum lines from the carb or the carb itself.
mtgldr
Feb 3, 2024 09:00 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
04stangman
Sep 26, 2015 09:33 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
