Ford 9"
Old May 16, 2007 | 08:40 PM
fast65's Avatar
fast65
Default Ford 9"
How do I know if I have a Ford 9" rear end? Are there any characteristics, markings or anything else I should look for? I have a 1965 GT coupe, it originally had an "A" code 289, and a 4-speed manual transmission. Any help is greatly appreciated. Thanks.
Old May 16, 2007 | 08:58 PM
69stangcoupe's Avatar
69stangcoupe
Default RE: Ford 9"
here you go
http://www.mustangandfords.com/techa...ive_basic.html
Old May 16, 2007 | 09:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Ford 9"
That is one of the most often asked questions on here. Here is a butt load of information that has been amassed over the last few years.
IX. DIFFERENTIAL AND AXLE:
8 inch or 9 inch rear end?
http://www.kevinstang.com/Ninecase.htm
http://www.ridgenet.net/~biesiade/Fordrears.html
http://mustangandfords.com/techarticles/127_0310_diff/index1.html
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
http://www.maliburacing.com/ford_9_inch/ford_nine_inch.htm
Which Ford cars have 9" rear ends?
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
Old May 16, 2007 | 09:17 PM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: Ford 9"
here is a very simple way to check. look at the pumpkin where the bolts are. if you can fit a socket straight onto the bolts than you have an 8in. but if you cant fit the socket straight on because the bolts are a little overshadowed by the cover, than its a 9in, duno if i made that really clear, but i think u guys know what i mean
Old May 16, 2007 | 09:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Ford 9"
ORIGINAL: Mustangdemon67
You made it very clear Demon. How's your golf game?
Old May 16, 2007 | 09:57 PM
BlackLX's Avatar
BlackLX
Default RE: Ford 9"
Another site
http://hipomustang.com/default2.asp?page=18
Old May 16, 2007 | 09:58 PM
fast65's Avatar
fast65
Default RE: Ford 9"
Thanks, guys you really helped, I'm pretty sure that it's not the stockrear endconsidering that the previous owner had swapped out the old 289 (got blown up) for a 302, also I remember seeing that hump that has been talked about so much. I'm going to check again tonight, and I'm crossing my fingers that it's a 9".
Old May 17, 2007 | 01:20 AM
Mustangdemon67
Default RE: Ford 9"
meh, im a bogey player
Old May 17, 2007 | 01:23 AM
BeastMachine69's Avatar
BeastMachine69
Default RE: Ford 9"
what's the benifit of installing a 9 inch rear end?
Old May 17, 2007 | 01:49 AM
superdavid's Avatar
superdavid
Default RE: Ford 9"
They don't brake when you race a Prowler out of a stoplight. .... not that I speak from personal experience or anything...
