Ford 9"
Old May 17, 2007 | 11:13 AM
dozierstang's Avatar
dozierstang
Default RE: Ford 9"
9's are tough axles...one of the best made by ford. The best way to see if you have a 9 is like Demon said, check the bottom 2 bolts on the housing. If you can get a socket on there then you do not have a 9" rear. Bad a$$ axles, I lucked up and have a 9" in both my stangs.
Old May 17, 2007 | 04:04 PM
highhilleer's Avatar
highhilleer
Default RE: Ford 9"
ORIGINAL: BeastMachine69
what's the benifit of installing a 9 inch rear end?
As mentioned - very strong and that has lead to the developement of a lot of performance parts such as different ratio gears, high strength axles, multiple options for limited slip, etc.
And for you NASCAR fans, it's the only rear end allowed by the rules. Yep Chevy, Dodge and Toyota teams all use the Ford 9".
Old May 17, 2007 | 05:13 PM
BeastMachine69's Avatar
BeastMachine69
Default RE: Ford 9"
cool!
Old May 17, 2007 | 05:26 PM
gothand's Avatar
gothand
Default RE: Ford 9"
ORIGINAL: highhilleer
... but are any of the actual parts on it made by Ford? I'm guessing that everything, including the housing, are aftermarket parts.
Old May 17, 2007 | 09:08 PM
mikethebike's Avatar
mikethebike
Default RE: Ford 9"
Unless it's a 31 spline Nodular 3rd member it's no stronger than an 8'....just heavier.
Old May 18, 2007 | 04:02 AM
gothand's Avatar
gothand
Default RE: Ford 9"
ORIGINAL: mikethebike
So a 31 spline with a standard cast case is no stronger than an 8"? I guess that also means that the Strange 9" aluminum case with 31 splines is no stronger than an 8" either? Hmm ...
Old May 18, 2007 | 04:06 AM
andrewmp6's Avatar
andrewmp6
Default RE: Ford 9"
a 8inch a 9inch and the 8.8 all can be built to hold some big power just depends on your wallet
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
mustangchef
Sep 4, 2015 08:08 PM
Luke9222
Sep 4, 2015 06:46 AM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
