Quick question about distributor vacuum advance
Old May 18, 2007 | 09:07 AM
Epic2112's Avatar
Epic2112
Default Quick question about distributor vacuum advance
I'm installing an Edelbrock carb, and it says to figure out if the vacuum going to the distributor is timed vacuum or full vacuum. Which is it?
Thanks
Old May 18, 2007 | 09:35 AM
paddy187's Avatar
paddy187
Default RE: Quick question about distributor vacuum advance
I think it is timed vacuum as it advances the timing so there should be no vacuum at idle. So full vacuum would make little sense imo.
Old May 18, 2007 | 10:08 AM
sxs191's Avatar
sxs191
+1 with Paddy. It's timed. Full vacuum would be a break booster hose or tranny vacuum line.
Old May 18, 2007 | 10:22 AM
Soaring's Avatar
Soaring
I ♥ Acer
Timed vacuum = timing.
Old May 18, 2007 | 11:08 AM
P Zero's Avatar
P Zero
Aka ported vacuum and manifold vacuum. You want ported so theres no advance @ idle.
-P.
Old May 18, 2007 | 11:21 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, the vacuum line hooks into the carb.
Old May 18, 2007 | 12:31 PM
NorCalTroy's Avatar
NorCalTroy
ORIGINAL: Soaring
Soaring, there are both timed and manifold vacuum ports on an Edelbrock carb. Maybe you should stick to answering questions about stock stuff.
Epic2112, you want the port on the front left of the carb. It is above the throttle plate and therefore only creates vacuum when the throttle plate is open.
Check out Edelbrock's website, there are excellent videos that you can download:
http://www.edelbrock.com/automotive_...ech_vids.shtml
Also check out this article about tuning an Edelbrock:
http://www.fordmuscle.com/archives/2...rockCarburetor
And here is a picture for you:
(this was during installation, I have since removed the plug on the timed vacuum port and connected my distributor advance to that port)
[IMG]local://upfiles/48823/E7C509B7D8914354884F9437D1C5B203.jpg[/IMG]
Good luck!
Old May 18, 2007 | 01:26 PM
6t9 stang's Avatar
6t9 stang
there should be instructions that come with the carb. I just installed a new edelbrock carb, im pretty sure you just unplug the vacum line that runs from the dizzy to the carb, and if the car runs normal you plug it in the recommended port on the carb.
Old May 18, 2007 | 03:02 PM
my77stang's Avatar
my77stang
wow, you giving out a b*tch slap with that post too?
Old May 18, 2007 | 03:38 PM
NorCalTroy's Avatar
NorCalTroy
No "b*tch slap" intended.
It's well known that Soaring doesn't use, or even like, Edelbrock carburetors, so it was just my opinion that if someone doesn't know about the equipment, it doesn't make sense to offer help with it.
