Steering column removal
Old May 19, 2007 | 07:53 PM
green_blurr's Avatar
green_blurr
Default Steering column removal
I cant get thisdamnsteering wheel off why?
[IMG]local://upfiles/43944/D9D1168CC89149B89AEAF6986B9803F0.jpg[/IMG]
[IMG]local://upfiles/43944/92B791D8E752432881C6D68A44082001.jpg[/IMG]
Old May 19, 2007 | 08:29 PM
papi_chulo's Avatar
papi_chulo
Default RE: Steering column removal
no idea how. but i was wondering if u can help me out since u got the pic up what is that thing next to the emergency brake that you pull?
Old May 19, 2007 | 08:42 PM
350kmileFord's Avatar
350kmileFord
If you're referring to the little **** between the column and E-brake that goes in and out a few inches, that would be the driver's side leg vent. Pull it out to open, push to close.
When I took off the Grant wheel that's in place, it was lightly pressed on. Had touse a pulley puller to get it off.
Old May 19, 2007 | 08:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, you either have to rent, borrow or buy a wheel puller.
Old May 19, 2007 | 09:19 PM
66JameStang's Avatar
66JameStang
Getting off the steering wheel is the hardest part mine broke in the process. But it is definately the only way to get it out and there is a rod right down the middle of the steering colum that is a huge pain. You must use a steering wheel puller or something that will let you get leverage behind it. If it is a six the steering rod is attached to the drive box and has to come out through the endine bay or at least mine was.
Old May 19, 2007 | 09:21 PM
green_blurr
Yay ! i got it off i had to bitch slap it around but it came off
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
