TANK GOING TOO FAST
Old May 21, 2007 | 07:08 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: TANK GOING TOO FAST
Are you smelling gas as you drive it? That's about 4 miles per gallon, and certainly not right for a 302. My father's 454 Chevy motor home got about 6. I would overhaul that carb and put some smaller jets in it.
Old May 21, 2007 | 09:24 PM
  #22
Bulldog66's Avatar
Bulldog66
I've gotta ask the obvious.
Have you re-filled the tank to see if infact it's a mileage issue or if there's a sender issue in the tank? Just because the guage might read empty does not make it fact.
Just curious.
Even on my trucks worst day I get 8 mpg. That's pulling a 20' boat with 4 people in the truck. (F-250 5.8 4X4 w/ 35" tires)
By your calculations, you're at 4-5 mpg. Unless you're just dumping raw fuel down it's throat, it's either going on the ground or there's a fuel tank playing tricks on you.
Cheers.
Old May 21, 2007 | 10:00 PM
  #23
66GTKFB's Avatar
66GTKFB
Bulldog - you took the words right out of my mouth. Forgive him a little, he's a Marine.
Jim
Old May 21, 2007 | 10:15 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JMD
ORIGINAL: USMCrebel
new shocks/springs, and my air pressure is good too timing is at 10*
IMO, you will find the excessive fuel consumption is a result of a carb issue as I stated eariler. This is where you want to start. Timing could be a contributing factor, but carb 1st!!
Absolutely. That carb needs an overhauling. Buy me a plane ticket and it will be done tomorrow. Can't do it through the monitor on my computer.
  #25
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
To start off Semper FI and yes i've refilled it twice and i've emptied the tank by hand 15 gal put the in milk jugs and poured them back in and still i drive about 60-80 miles and im empty again.
Old May 21, 2007 | 10:18 PM
  #26
USMCrebel's Avatar
USMCrebel
how do you overhaul it ?
Old May 21, 2007 | 10:23 PM
  #27
Soaring's Avatar
Soaring
I ♥ Acer
I have a download on how to overhaul a Motor craft 2150 on another thread here.
What carb do you have?
Old May 21, 2007 | 10:27 PM
  #28
USMCrebel's Avatar
USMCrebel
a weber... thats all i know, i havent looked
  #29
66GTKFB's Avatar
66GTKFB
Just a rub from a Tin Can Sailor. I'm reading Brad Kasal's book right now. Semper Fi, Jar Head (note - capital letters)
Jim
Old May 22, 2007 | 12:37 AM
  #30
JMD's Avatar
JMD
ORIGINAL: USMCrebel
A Weber might be the same as an Edelbrock or modern Carter.... But maybe not,, need more info!!!
