help with '73 dash and cluster removal
Old May 21, 2007 | 05:12 PM
flyingfool's Avatar
flyingfool
Default help with '73 dash and cluster removal
I need to remove the instrument cluster from my base model '73 but when i went to take off the front pannel, i couldnt get it past the steering column or under the dash. do i need to remove the entire dash to get in there? and if so, whats the easiest way to go about it?
Old May 21, 2007 | 05:25 PM
66GTKFB's Avatar
66GTKFB
Default RE: help with '73 dash and cluster removal
I suggest you get the 1973 Mustang Body Assembly Manual (NPD $16).
Jim
Old May 21, 2007 | 09:17 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
remove the plastic trim from around the column,remove the screws to the cover of the sluster and pull it out then remove the screws holding the cluster in place pull it out slightly and now you have to relase the speedo cable from the speedometer do this then the cluster will come out a light bit more and you can release the wiring from the printed circuit board on the rear of the cluster
Old May 21, 2007 | 10:04 PM
66GTKFB's Avatar
66GTKFB
Old Chinese proverb - 'Picture worth thousand words'. Buy the book.
Jim
Old May 21, 2007 | 11:09 PM
Yonco's Avatar
Yonco
the book didnt help for me, i just unhooked it, removed as many plactic pieces( and the dashpad) and it slipped out the top -Jon
Old May 22, 2007 | 04:30 AM
flyingfool's Avatar
flyingfool
hmm, id agree with the picture worht a thousand words....but, i did all the panel unscrewing, and after all that, i couldnt get it past the upper dash pad without really pulling on it and i dont want to break it or anything.
Old May 23, 2007 | 12:28 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I usually just take the steering wheel off.
Old May 23, 2007 | 10:35 AM
Mach1972's Avatar
Mach1972
You will need to drop the steering column. First remove the plastic collar and then the four nuts/bolts that hold the steering column in place. This will provide enoughclearance to remove the panel.
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
