1968 gas cap
Old May 22, 2007 | 08:39 PM
JJ68Mustang's Avatar
JJ68Mustang
Default 1968 gas cap
Hey guys, first post! I have a question, if I tighten the gas cap down all the way for my 68 mustang it's crooked a bit, to have it straight I would have to leave it slightly loose. Has anyone else had problems with this? Is there a way to fix it? Would buying a new gas cap fix it? Thanks!
-JJ
Old May 22, 2007 | 08:42 PM
colostang's Avatar
colostang
Default RE: 1968 gas cap
Not sure about this, but would a thicker gasket/seal help?
Old May 22, 2007 | 09:21 PM
66GTKFB's Avatar
66GTKFB
I put a second cork gasket between the filler pipe and the body on my cars, mostly for the additional clearance but it helps put the cap back on as well.
Jim
Old May 24, 2007 | 03:03 PM
JJ68Mustang
Nice, thanks, I'll give that a try and see if it helps!
Old May 24, 2007 | 06:04 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I used to have a similar problem on my 67. I cured it by putting a pop-open gas cap on. Much cooler.
Old May 24, 2007 | 07:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, it just makes sense that if the gasket is thicker, the cap will bottom out sooner bringing it back to sitting up straight.
Old May 24, 2007 | 07:36 PM
JJ68Mustang
Something like this?
http://www.mustangsplus.com/Merchant...e=filler_tubes
Old May 24, 2007 | 07:44 PM
66GTKFB's Avatar
66GTKFB
Actually no - i would recomendthe $0.60 variety from National Parts Depot (2007 pg91 p/n 9076-1). The one from Mustangs Plus is the high tech, high speed, restomod, high price for the discriminating buyer same thing.
Jim
"Speed costs money, how fast can you afford to go?"
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixer4Life
Oct 12, 2015 04:26 AM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
