66 Convertible top problems
Old May 23, 2007 | 10:24 PM
19stang66's Avatar
19stang66
Default 66 Convertible top problems
So my dad finally got his 66 Vert. It was being shipped from California to here (MN). Our problem is when trying to close the top. The pins that are supposed to go in the holes aren't lining up so as to being able to latch both sides securely. It also seems the hydraulic arms, if it has them, are bad. The top is brand new and my dad thinks a company called March made the top. It's a power top if that makes any difference. Thanks.
Old May 23, 2007 | 11:51 PM
Wayne67vert's Avatar
Wayne67vert
Default RE: 66 Convertible top problems
Try pulling down at the center hinge, just above your shoulder as you sit in the seat,align the pin andclose the latch. Do this all at the same time. Also have the rear quarter windows rolled down a little.
Wayne
Old May 24, 2007 | 01:18 PM
19stang66's Avatar
19stang66
We are only able to do that on the drivers side. The passenger side pin won't line up in the hole which makes it impossible for the latch to catch. Anyone else have suggestions?
Old May 24, 2007 | 01:50 PM
66GTKFB's Avatar
66GTKFB
I recomend the 1966 Mustang Body Assembly Manual (NPD $16) that has the factory adjustments included as well as window adjustments or the 1966 Service Manual (NPD $46.95) that has a lot more info.
Jim
Roger Mabry
Jun 15, 2016 08:27 AM
importsmasher
Oct 9, 2015 04:42 PM
Calizic
Aug 28, 2015 01:46 PM
robjh22
Aug 17, 2015 07:35 AM
Mustang Sally72
Aug 11, 2015 07:54 AM
