problems
Old May 25, 2007 | 03:57 PM
66mjchiara's Avatar
66mjchiara
Default RE: problems
i feel it is the spark as well only im flying solo here and there is no someone to help crank. the manifold would be fine to test the spark on correct?
Old May 25, 2007 | 04:00 PM
67mustang302's Avatar
67mustang302
Should be, but you might wanna keep that spark away from any fuel source
Old May 25, 2007 | 04:05 PM
66mjchiara's Avatar
66mjchiara
haha thanks, if not could this be a timing issue even though she has started and ran fine for months including last night? god i hope not I hate timing sdjustments i never know what im doing.
Old May 25, 2007 | 04:15 PM
longlive289s's Avatar
longlive289s
well i doubt it would be timing since it was running fine last night, try and get a neighbor to help you out and look at the plug when you pull it out, just tell em you need to borrow them for a minute
Old May 25, 2007 | 04:19 PM
66mjchiara's Avatar
66mjchiara
you mean i have to let go of my pride and let a stranger sit in my baby?
Old May 25, 2007 | 04:21 PM
longlive289s
no...they can just stand outside and hold the plug and tell you if its arching.....god knows none of us want some stanger in our car
Old May 25, 2007 | 04:23 PM
66mjchiara's Avatar
66mjchiara
haha yeah watch their face when i explain to them an arch of electic current is going to shoot near their hand.
Old May 25, 2007 | 04:32 PM
longlive289s
just tell them what doesnt kill em only makes em stronger and not to be a wuss
Old May 25, 2007 | 04:39 PM
gothand's Avatar
gothand
You don't need a neighbor. Do like the others said and pull a wire and put a plug in it and hold it up against a grounded metal source. Turn your key to the on position. Pull the shielded wire off of the 'S' terminal on your solenoid. Make sure your car is in neutral if it is a manual!!!! Assuming you don't have a remote starter switch, touch a screwdriver across the solenoid, touching both the positive side of the battery and the 'S' terminal. Your car will turn over and you should see spark on the plug. Good luck!
Old May 25, 2007 | 04:58 PM
66mjchiara's Avatar
66mjchiara
alright i dont even know this was possible, i had a neighbor get in and start it for me, she put her foot on the accelerator and before she even turned the key i noticed the carb was not opening its was stuck! i didnt even know that was possible i opened it by hand and she started it right up its running fine.[8D]
