Clutch Installation
Old May 26, 2007 | 01:29 AM
scuf23's Avatar
scuf23
Default RE: Clutch Installation
or like that ...
[IMG]local://upfiles/62696/924B628155194C02AC3D5E1E3E6B8A18.jpg[/IMG]
Old May 26, 2007 | 01:30 AM
scuf23's Avatar
scuf23
and I don't want to go to the expense of a centerforce dual friction ... neither do I have the need (I think )
Old May 26, 2007 | 09:48 PM
scuf23's Avatar
scuf23
Follow up on my previous message - I ended up buying the roller bearing for the pilot bearing and a new set pressure plate / clutch - I went for the diaphragm type and already installed them pretty easily
Transmission will go in tomorrow or Monday ... will keep you posted!
Old May 27, 2007 | 01:45 PM
scuf23's Avatar
scuf23
Well I did not have time yesterday to put the transmission back in, hopefully today ...
I did get the new clutch in (diaphragm pressure plate and roller bearing for the pilot bearing), and installed the bellhousing back in, as well as the throw out bearing ... see pictures
Is there anything I can check / do to make sure everything is OK prior to putting the transmission in? it would sucj to have to pull it back if something is wrong with what I did!
Thanks
[IMG]local://upfiles/62696/41A1331ED9554D49A412A36F3F006BBF.jpg[/IMG]
[IMG]local://upfiles/62696/88AE0292F1A14894B9EF9791269DE0AE.jpg[/IMG]
Old May 27, 2007 | 01:54 PM
JamesW's Avatar
JamesW
As long as you used the little plastic guide to hold your clutchin place while attaching the pressure plate, there's not much else to do.
Stab it and go!
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
