Clutch Installation
Old May 25, 2007 | 03:21 PM
scuf23's Avatar
scuf23
Default Clutch Installation
I'll be putting back my clutch this w-e; is there any lubricant to be installed for the pilot bearing? what about the throw out bearing? any other recommendations?Thanks!
Old May 25, 2007 | 05:48 PM
gothand's Avatar
gothand
Default RE: Clutch Installation
Both the pilot bearing and the throwout bearing are usually pre-lubed, depending on the brand you get. The Ford Racing pilot bearing instructions specifically state not to add any additional lubricant to the pre-lubricated bearing so as to not to have it run out into your clutch disc. I've had a throwout bearing or two that did have a grease fitting which I just used some wheel bearing grease I believe.
Re-reading your post, you do have a new pilot bearing and throwout bearing, don't you? Considering how easy and affordable they are to replace now, I'd do it. To get the old pilot bearing out you'll either need a puller or they sell a special fitting which you attach a grease gun to that will force it out. Last but not least, make certain to properly clean all the mating surfaces and line up the disc with the alignment tool. Having longer bolts with the heads cut-off, threaded into the bellhousing will make your life a lot easier as well.
Good luck!
Old May 25, 2007 | 10:35 PM
JamesW's Avatar
JamesW
Consider picking up a roller pilot bearing in lieu of the standard oiled bronze. They're not that expensive.
Old May 25, 2007 | 10:47 PM
67mustang302's Avatar
67mustang302
Yeah, roller pilot bearings are the best way to go.
Old May 26, 2007 | 12:57 AM
scuf23's Avatar
scuf23
Well, I was planning on re-using my pilot bearing and throw out bearing but sounds like I shouldn't
All the existing components are already out, pilot bearing came out without any tool, just pulled it! I will be going to mustang unlimited tomorrow morning to pick up my new clutch assembly ... here again any recommendations? I have a stock 289 and I will not be doing anything fancy with it
Thanks
Old May 26, 2007 | 01:10 AM
JamesW's Avatar
JamesW
are you running a 3sp, 4 or 5 sp? old or later model?
Old May 26, 2007 | 01:13 AM
scuf23's Avatar
scuf23
4 speed toploader - not sure about old vslater model, what are you referring to?
Old May 26, 2007 | 01:21 AM
JamesW's Avatar
JamesW
It you're running a factory 289 and a factory 4sp with all original equipment...then I'd skip Mustangs Unlimited and go to one of the reputable local auto parts dealers like NAPA and get a new clutch. It will have as good a warranty, be the same brand name, and be cheaper than MU.
Old May 26, 2007 | 01:26 AM
scuf23's Avatar
scuf23
OK - NAPA sounds like and idea, I should have one around
What about the pressure plate? stock type (3 fingers)ordiaphragm type? comments? experiences? Thanks (again)
Old May 26, 2007 | 01:28 AM
scuf23's Avatar
scuf23
i.e like this
[IMG]local://upfiles/62696/51DEE13F2DFE45929E08D716AA8CE2D8.jpg[/IMG]
