valve covers
Old May 25, 2007 | 09:27 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default valve covers
so i have these "289 powered by ford" valve covers on now, but i want something a little different, i was thinking about these trick flow ones cuz they give it a "racey" look even though its mostly stock[8D]
problem is, it says for race use only because a hole has to be drilled for the breather.....what would happen if i didnt do that i have it now BTW.
Old May 25, 2007 | 09:29 PM
EmperorOfChicken
Default RE: valve covers
its the shiney thing on the valve cover [8D]
I think those valve covers would look really good on my motor (not a chrome fan, as you can tell i have the natural finished intake and headers so i think they would pair up nicely )
Old May 25, 2007 | 09:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: EmperorOfChicken
Don't you remember the thread we had a few weeks ago about buying covers that had to be drilled? If not, then do a search and read that thread so you know what to do. I personally think you are not too smart to put those covers on that beautiful engine as the ones on there are perfectly fine and period correct and look a whole lot more racey than those do.
Old May 25, 2007 | 09:44 PM
EmperorOfChicken
nah havent been on in a few weeks, just finished exams so the forums took a back seat[8D] do you recall the title?
Old May 25, 2007 | 10:11 PM
VeronicaScz's Avatar
VeronicaScz
Hello.Are you asking what would happen if you just left them closed, as in don't drill them? If yes, that would not be such a great idea for a car that you plan on driving on the street. The eventual result would probably be a fire in the crankcase. The purpose of a pcv valve is to ventilate the crankcase. I guess that's why they call it a Positive Crancase Ventilation valve.Before the fire , the symptoms would be really, really excessive oil consumption due to the pressure build-up on top of the heads and below the pistons, which would then turn into oil leaks when the pressure build-up blows a gasket or a seal somewhere, and eventually there would be just enough blow-by gas accummulated in the crankcase under the right conditions to ignite itself. That's why thet call them trickflow. The trick is that flow of flammable gases heading for your crankcase.
Old May 25, 2007 | 10:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: VeronicaScz
Damn woman, you are good. How about a hug? (TV advertisement aboutTime Warner cable) Are you going to be able to make it up to my house on the 4th of August,and show your car in the MOCA Ford show? How's your golf game?
Old May 25, 2007 | 10:25 PM
JamesW's Avatar
JamesW
You need a breather and Positive Crankcase Vent system in order to keep the air pressure normalized inside the motor. The PCV routes the oil/gas laden air back into your intake so it can be burned off.
Not having your valve covers vented will cause air to build up in your valve train area and it will explode*....
(* just kidding)
Old May 25, 2007 | 10:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JamesW
(* just kidding)
Yeah, just kidding is appropriate. No engine is going to explode if not properly vented. The tree huggers have made us come to this event that all gasses must be recycled. Is it a bad thing, or is it a good thing? This is not a political or global warming discussion forum so I can't give you my thoughts on that issue.
Old May 25, 2007 | 10:43 PM
EmperorOfChicken
thanks all three of you, I dunt wanna burn up my motor[:@][&:] looks like if i get those they will meet the buisness end of a drill[8D]
Old May 25, 2007 | 10:48 PM
JamesW's Avatar
JamesW
I think V has the most appropriate explanation on the need to vent the gasses. I don't know about a fire, but I can see the fuel laden fumes causing sludge and deteriorating the crankcase oil quality.
The 5.0s that those valve covers are meant for vent through the back of the intake manifold.
