Used Block Tests/Machining
Old May 29, 2007 | 12:21 AM
urban_cowboy's Avatar
urban_cowboy
Default Used Block Tests/Machining
What advice do you guys have on building out a new engine from a used block with relation to machining and testing the block. Lets assume the engine has never been bored, but is used. What tests do I need to have done to insure the block is in the best shape it can be in before building it out? What machining should I do before building it out? I have heard of terms like sonic testing, but I am a complete novice at engine rebuilds.
This project will probably be a 351 Cleveland and my target horsepower is 450hp. RPM will not be anything crazy, but should spin up to 5500-6000K. The use will be a weekend toy that will melt tires. No racing and not a daily driver, but should last and hold up to a couple hundred mile drive on the weekends.
Thanks for the info in case I forget later.
Old May 29, 2007 | 12:56 AM
mustanglover66's Avatar
mustanglover66
Default RE: Used Block Tests/Machining
I work for a crate engine builder, we use mostly used blocks. Each block gets visually inspected for defects and magna fluxed before machining and pressure tested after honing. Here lately about 40% of the blocks have been junk so the sooner you can find problems in the process the cheaper it cost you. and before you ask we don't do clevelands thats why I didn't sujest us in your other treads. But if you want a stroker 302 or winsor motor we love to talk to you. Heres the link so you know who I'm talking about.http://tandlengines.com/
Old May 29, 2007 | 01:05 AM
my77stang's Avatar
my77stang
just tossing this out there, but shouldnt you guys wanna tackle whatever a customer throws your way? i mean, a C isnt a W but a motor is a motor ya know (we were building everything from postal jeep 2.5 GM 4 bangers to dohc japanese V6's to semi truck diesels)
Old May 29, 2007 | 02:07 AM
mustanglover66
You would think that but from what I've been told with the retooling cost what they are we just can't do it at least not right now. But I guess if enough people call asking for them he may change his mind.
Old May 29, 2007 | 02:12 AM
superdavid's Avatar
superdavid
I went through about 6 blocks before I found one acceptable for my 408w build. Some were cracked, some already bored .30, some wouldn't clear at .30...
Old May 29, 2007 | 04:19 AM
andrewmp6's Avatar
andrewmp6
depends on who builds it and your budget alot of oval racers here have to use oem parts and the way they drive and the hours of hard driving they take should kill the engine it dont
Old May 29, 2007 | 10:43 AM
urban_cowboy
So, Magnafluxing is a must. What about decking, honing the mains, or checking for bearing alignment? The big question in my mine is what all should be checked out or fixed before a block can be stamped "good"?
Old May 29, 2007 | 12:02 PM
my77stang's Avatar
my77stang
honing the mains = checking bearing alignment. 95% of the time they do not need to be align honed, which is good because it will end up giving you a sloppy timing chain unless you get a slightly undersized unit.
magnafluxing uses metal powder with a large electromagnet to detect cracks. they will check the block in the common areas where they crack.
if you REALLY wanted to go a step further (which if the motor currently runs you should not need to) would be a pressure test, to make sure the cooling passages are not going to leak into any place they arent supposed to.
the machine shop can throw a bore guage down a couple cylinders and tell you if they think its gonna clean up at .030, .040, or .060 within about 2 minutes. i personally dont know how meaty the C's are for being able to bore .060...... but if .030 wont make it and .040 will i would have no problem at all going .040 on my own motor. hell, i would most likely have no problem going .060 on my own motor.
Old May 29, 2007 | 03:10 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ORIGINAL: my77stang
you can get a line hone just dont line bore cause thats what gives you slop in the timing and they make timing sets for that also JSYK
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
