sloppy shifter
Old Jun 1, 2007 | 02:17 AM
tvra65's Avatar
tvra65
Default sloppy shifter
Hey guys great to be in your forum as a new member I have a 1965 mustang coupe with a 289 and C-4 trans. My problem is i have purchased the new spacers to repair the shifter but not sure how to install them correctly can anybody help or have done the repair in the pastyour help will be greatly appreciated.
Old Jun 1, 2007 | 03:08 AM
66GTKFB's Avatar
66GTKFB
Default RE: sloppy shifter
In step order:
1. Jack up and prop the car so you can get to the left side of the transmission.
2. Remove the arm from the shifter to the transmission. Do not loosen the adjusting nut at the shifter, just pull the pin at the arm at the transmission end.
3. Lower car.
4. Remove shifter handle. Reqs an allen wrench.
5. Remove 4 screws holding down the shift bezel. Console bezel is similar.
6. Remove 4 screws holding down the shifter to the car and remove shifter. There is a wire for the 'gear' indicator lamp that needs to be disconnected.
7. Remove 4 screws holding down cover plate.
8. Remove rubber plug on RH side.
9. Remove lock nut and slide shaft out LH side.
10. Remove bits and pieces of plastic bushings.
11. Clean everything - well.
12. Lightly apply some white lithium grease to the shaft and bushings.
13. Reassemble - it is possible to overtighten the lock nut so check the shifter's movement often as you tighten the nut - in the reverse order from step 9.
Jim
Note: On the arm to the transmission, there is awavy spring washer and a flat washer that go on in that order then the pin.
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
