progress
Old Jun 2, 2007 | 08:33 PM
Tony R's Avatar
Tony R
Default progress
here is the state of my 65 as of now. waiting for a few days off so I can blast and prime.
[IMG]local://upfiles/64293/37793DA58B294C99BDE4CE834A1AB74B.jpg[/IMG]
Old Jun 3, 2007 | 12:47 AM
hity645's Avatar
hity645
Default RE: progress
Nice did you make that yourself?
Edit: The Rotissere
dcohen's Avatar
dcohen
what happened to that cowl panel?
Old Jun 3, 2007 | 01:04 AM
shr's Avatar
shr
wow.....looks like you are gonna have a ton of fun! how high is your garage ceiling? it looks pretty low.
Old Jun 3, 2007 | 01:54 AM
Tony R's Avatar
Tony R
I made the rotissery my self. couldn't see spending 800 and up to buy one. I have been filling holes in the engine compartment that arent neded any more and I had a hole I had to make a patch panel for by the battery box. I also smoothed over the vents. Its amazing what one can do in a little two car garage. Nine foot ceilings.
Old Jun 3, 2007 | 01:55 AM
Tony R's Avatar
Tony R
heres the undercarriage.
Old Jun 3, 2007 | 03:47 AM
andrewmp6's Avatar
andrewmp6
looks like he welded the cowl vent shut which you can do if you a aftermarket heat/ac is it more or is it missing a torque box on both sides
Old Jun 3, 2007 | 03:39 PM
66GTKFB's Avatar
66GTKFB
Andrew, I got about half of what you entered. Periods (located under and to the right of the letter 'L') would make your posting coherent.
Tony, As to the welded up cowl, what is going to be your heat source? Washington is not know for it's abundance of plam trees.
Jim
Old Jun 3, 2007 | 03:51 PM
Tony R's Avatar
Tony R
I was either thinking of taking air from between the splash shield and the door pillar or looking into making it recycle out of the interior. That was going to be one of my future questions here to see what any of you all did but since you already brought it up what do you recomend?
Old Jun 3, 2007 | 04:20 PM
66GTKFB's Avatar
66GTKFB
I have one of those plastic cowl covers for winter (it does rain in Northern California off and on) driving and the heater works by keeping the heater door on the RH side open. The fan provides circulation. You could do the open door thingor remove it altogether. Fresh air via the wings and windows are your only source. Cutting a new hole only leads to a way to get moisture in. In any case, I like your solution - weld the problem shut.
Jim
