Air Pump/AC Help!
Old Jun 3, 2007 | 09:14 PM
ddnuts's Avatar
ddnuts
Default Air Pump/AC Help!
Hey all, I have a '67 Coupe 289 . I wanted to know if I could remove the air pump and still have the factory AC still work? The A/C doesn't work right now, but I plan on having it repaired (if possible). Or should I take off the belt that goes to both the air pump and AC and enjoy the extra HP? Thanks in advance.
Old Jun 3, 2007 | 09:23 PM
66GTKFB's Avatar
66GTKFB
Default RE: Air Pump/AC Help!
There's another post on this same subject and if memory serves me, you need an idler pulley located on the right hand side of the engine to have the A/C drivebelt clear the fan pulley without the smog pump.
Jim
Old Jun 3, 2007 | 10:20 PM
ddnuts's Avatar
ddnuts
Will it hurt the AC pump to not have a belt on it or will it seize up. Also, will it make a noticable HP difference?
BTW, thx Jim
Old Jun 4, 2007 | 12:57 AM
66GTKFB's Avatar
66GTKFB
It won't hurt the pump, you just won't have air conditioning. The bad news is - what ever refrigerant is in your A/C system may (read will) eventually leak out. It's a damned if you do, damned if you don't situation - smog pump or A/C.
As to engine power, all belt driven accessories, power steering, air conditioning and smog, use energy, aka horsepower, so the simple answer is yes.
Jim
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
