motor mounts
Old Jun 6, 2007 | 10:17 PM
quinchem's Avatar
quinchem
Default motor mounts
Does anyone know if the motor mounts off a 66 289 will line up putting the 289 into a 68? Thanx
Old Jun 7, 2007 | 01:31 AM
66GTKFB's Avatar
66GTKFB
Default RE: motor mounts
Yes, no and maybe. They should, even if they are the 64 to early 65 cast iron mounts. The mounting holes in the frame should be the same, however, I would be more inclined to use late 66 or 68 engine mounts as the frame brackets and insulators are of a better design. Don't bother with 67, they have a different frame, bracket and insulator angle.
Jim
Old Jun 7, 2007 | 01:43 AM
Aussie66Fastback's Avatar
Aussie66Fastback
pretty sure they're different
try anyone of the online mustang vendors to see pics
Old Jun 7, 2007 | 01:47 AM
66GTKFB's Avatar
66GTKFB
Ben,
I got 68 mounts in my 66 hardtop 289 and the engine hasn't fallen out yet.
I'm doing some reading on wine and I see that the Barossa Valley has a good reputation. You involved or know people in the wine business?
Jim
Old Jun 7, 2007 | 02:01 AM
mat11089's Avatar
mat11089
ORIGINAL: 66GTKFB
Jim
No tothe early style statement, theyused a downward facing bolt and later ones two brackets that met and the bolt went through horizontally.but i do believe the 68 and 66 are the same.
Old Jun 7, 2007 | 02:19 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes they will fit and the 65 mounts are a decent design actually alot of people use them instead of a solid mount since you can drill a hole and put a slightly snug bolt thru it to keep the mount from ripping apart. with that said shy away from 67 mounts they are a 1 year deal and are quite hard to come buy. the 68-70 "ear type mounts" are what alot of people prefer for header clearance. but i believe most who run the 351w/351c prefer the 65 mounts as it raises the motor in the engine compartment allowing more room for clearance
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
