suspension info please
ORIGINAL: IM RICKY BOBBY
ok, so the M2 kit puts extra load on the frame, isnt there a way to strenthen the frame, like with sub frame connectors or a chassis stiffener??
based on strickly handling how would you guys rate it, would staying with the original design and just put performance stuff on there be as good? performance and cost?
Unless you're going to compete in it at a moderately serious level (and the rules permit what you have in mind) I'd stick with carefully chosen performance parts for what you have. Don't just take the information that's provided in advertising literature and on web pages as your only source. Hunt down independent reviews and comparative tests if available. And ask specific questions here. Read Fred Puhn's "How To Make Your Car Handle".
It's not that the M II suspension is all that bad - in its original chassis it can be made to work quite well in spite of its shortcomings. Back in the 70's a good choice of essentially bolt-on suspension goodies could give you a car that on performance street tires would set faster run times at autocross than most other cars of the day on similar rubber. And about 0.85 lateral g's was available. BTDT. You'd need to do quite a bit more work to get similar results swapping this suspension into a car that's longer/wider/several hundred lbs heavier.
Norm
Like Norm and others have alluded. The II suspension is weaker than the classic suspension, so just beef up the classic suspension. Sounds like you have made that intelligent decision though. Why am I even here?
atomsk the 67-70 both ford big blocks will bolt in .when i autocross my mustang since i have coil overs front and rear it moved me up to the mod x class which makes it harder to win.opentrackers parts keep it oem ford desgined so you wont get stuck racing in a harder class
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
