Which intake for a 351C 2V
I am trying to switch the intake and run the car a bit befor i pull the engine which would you perfer and why. Or suggest something else. Remember i am trying to get 320HP at the wheels. I will be putting in a cam latter.
I'll second the Parker, it is art... and a manifold.
I'm running an RPM air gap, if you want 320 (400+flywheel)at the wheels out of a 351 you may want to go with the Parker or a single plane.
I really like the looks of that Parker. It looks like it will raise the height of the carb though. Any clearance issues? It also has only one intake hole instead of 4. Will this intake work on a basically stock engine?
