Customer Radiator Hoses
Anybody have expierence with customer radiator hoses?
I would almost prefer a plain old black rubber hose. But the problem I have is that the hose length is not going to be any where near stock for the upper, and the lower is going to the opposite side. I see some you can make up with chrome outer covers. But if I remember right, those clamp ends are kinda cheesy. Anybody got any thoughts?
BTW, upper is 1 3/4" and the lower is 2".
Same here.. I cut up some old hoses & mocked up the distance. Also, as ugly as it is, using an inline filter helped in fitting the hose length..making it a 'cut to fit' application.
James, you could probably take the hose you have now with the filter attached to it to a large automotive center and find one that matches it without the inline filter. That just doesn't look right.
Perhaps.
The 5.0 radiator hoses on the Fox bodies have that funky 'up and over' bend to clear the alternator, which looks odd. I'd rather have the filter than not though. It works well.
